Show Your Road Racing Iron
#101
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
72 Lejeune CdM by L Travers, on Flickr
And in the wild.
Grafton 2 by L Travers, on Flickr
Likes For CV-6:
Likes For qcpmsame:
#103
Quoted: 4512 Post(s)
Liked 6,385 Times
Gonna add these since DD said they get a pass.
Early 70's Bottecchia Pro, need to get some decals for it.
1986? Scott Paisley as found.
Likes For merziac:
#104
A few indoor pics because it is 12 degrees outside and we have had three consecutive snow days for the kids...
Tesch, Tesch, Tesch:
Trek, Appel
Kono Allez
Lemond, Bottecchia
Trek, Appel
Kono Allez
Lemond, Bottecchia
#GCVintageBicycles for pics of C&V bikes and parts.
Likes For Shrevvy:
#105
And because it is so pretty, a Billato cromovelato 50th Anniversay...pic does not do it justice.
Likes For Shrevvy:
Likes For plonz:
#107
Bikes: A few
Quoted: 289 Post(s)
Liked 196 Times
'69-73: The finished ones. On the bench is a '7? Frejus, next in line a '71 Masi, and a '7? Guerciotti
Likes For satbuilder:
Likes For embankmentlb:
#109
Quoted: 2588 Post(s)
Liked 4,824 Times
This one had an extremely long gestation period before it was finally built into a working bike. Even so, as of today it still isn't 100% "finished"...
1985-ish Casati Perfection. Purchased well-used from a seller at the 2010 Seattle Bike Swap, it originally had a smattering of Casati pantographed components and no wheels. I took it down to the frame/fork/HS and began planning what to do with it. If it's not apparent from the following photo, the original paint was a metallic/pearl pink. While there was some remaining original color (mainly in the areas not subjected to direct sunlight), the majority of the "finish" was simply gold undercoat - which would transfer to my hands whenever I handled the frame. I let it sit for four years while I worked on other projects and finally decided it would be too much work and too expensive to attempt to return it to its original finish, so I moved the panto bits on Ebay and sold the frame/fork in 2014.
Fast-forward to 2017 and I re-discovered the frame - in exactly the same shape I sold it - while perusing my local CL. The price was stupid-low and as I'd recently finished up a bike-as-art project using a bare-metal approach, I immediately knew how I could finally turn this dog into a rider, if not a looker. So, I bought it back (seller was the same guy I sold it to three years previously) and promptly contacted our own @gugie at the Atelier to make some modifications. He closed up the internal routing fittings for brake and gear cables, added gear cable guides on top of the shell, offset brake cable guides on the top tube and brazed a diver's helmet gear cable stop on the chainstay, too. When I picked it up it had a beautiful media-blasted finish which I intended to keep clean and tidy - my plan was to "seal" it with clear, matte lacquer, but before I got it home I'd already nicked it a few places and the even finish was no more. No matter; instead, I went over the whole frame with steel wool to give it a uniform appearance, applied the decals purchased from Ebay in the interim, then sealed it with a can of Krylon Matte Clear. Total outlay on the finish: $7.99.
I built it up with my now-standard Campy NR/SR mix and had a complete bike by August 2018. In 2019 I converted a lot of the components to try something different, ending up with a Sugino crank, Suntour Superbe track pedals, Suntour Cyclone derailleurs, Nitto 65 post, Suntour Superbe brakeset, and an obscenely-large pair of Suntour gear levers; it ran in this configuration for about a year:
Sometime in 2020 I converted it back, but kept the Nitto post. This was my go-to bike for gravel rides, and saw action at Cino 2021. I also chose this bike for my open-ended van-conversion road trip, but had to put it back into storage after a "bit of a glitch" temporarily ruined my nomadic plans. But not before I got one final ride on it, a wet 50-miler in Oregon that soaked the bike so much the leather covering on the Flite saddle began separating from the foam base! It was deep-cleaned, then placed back in storage in November; when I get back up to WA I'll have to figure out a way to fix the saddle...
The finish has held up well. I've wet-sanded some rust-blooms on the top tube a couple times and re-applied the clear coat, but to be honest, I think the other rust-blooms add a certain charm so I'm leaving them.
The bike as it appears (for the most part) today:
DD
DD
#110
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,601 Times
#112
Quoted: 821 Post(s)
Liked 255 Times
My McLean Perfect Pleasure is pretty zippy.
It's pretty similar to this nowadays, but I have GP 5000's (700x32) on there atm.
https://www.continental-tires.com/bi...rand-prix-5000
I also ride exclusively with Shimano XT or XTR pedals.
Likes For gomango:
#113
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
That is spectacular. It just doesn’t get better. I have had a lust affair for the Prestige shop Peugeots for decades. So, that should be a 1979. In my view, that may be the most desirable year as it represents the last year that a major racing team was equipped with centerpull brakes, and they did them quite right. The fact that it was Pascal Simon’s just puts it right over the top. Fabulous.
Likes For 1simplexnut:
Likes For jimbaddabim:
#115
Quoted: 604 Post(s)
Liked 1,064 Times
91 OS Paramount
Likes For tkamd73:
#116
Quoted: 604 Post(s)
Liked 1,064 Times
Oh yeah, this one too
Tim
82 Bianchi Champione del Mondo
Tim
Likes For tkamd73:
#117
Quoted: 225 Post(s)
Liked 1,101 Times
Fast
Faster (only because it’s red)
No history on the De Rosa but it had this “team” saddle on it when I got it
Too fast
Too fast
Montana, where men are men and sheep are lying little tramps.
Likes For majmt:
#118
Quoted: 2338 Post(s)
Liked 2,824 Times
I think the fork is bent on the last red one
Likes For squirtdad:
#119
Quoted: 964 Post(s)
Liked 1,451 Times
That's mine, and is full of tools and snacks. It's super rare we Cambridge Vitus-ers ever go a ride without something breaking or otherwise falling apart! I am the one expected to fix it all.
Likes For scarlson:
#120
Bikes: 87 Bianchi X4, 95 Bianchi Ti Mega Tube, 06 Alan Carbon Cross X33, Gold plated Columbus AIR Guerciotti, 74 Galmozzi Super Competizione, 52 Bianchi Paris Roubaix.
Quoted: 259 Post(s)
Liked 540 Times
Likes For mackgoo:
#121
1974 Mirella
Likes For NitroExpress:
#122
1973 Motobecane Le Champion
#123
1999 Waterford 2200
Likes For sced:
