WTB: Triple crankset
Found what I was looking for, thanks
Bikes: 1972 Fuji The Finest | 1990 Bianchi Giro | 1999 LeMond Buenos Aires
Quoted: 151 Post(s)
Liked 303 Times
If you don't find a source here, your description reminded me of Stronglight Impact triples, double check BB, looks like it takes a 115mm JIS according to Stronglight (but Spa says 110). What speed chain are you planning to use?
https://www.spacycles.co.uk/m8b0s109...-Impact-Triple
Stronglight - Pédalier
Good luck!
Good luck!
Good luck!
Good luck!
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 217 Post(s)
Liked 198 Times
I have a classic 80s Sugino AT triple, currently set up as a double. 175mm arms. If this is in the right ball park, will follow up with pics.
edit: i have an inner granny (28 i think) to add to the mix as well, can probably get something close to your preferred range.
I have a Deore XT 737 crankset in 175 if it interests you. 94/58, but I only have an inside ring for it.
Likes For natterberry:
Señor Member
Quoted: 284 Post(s)
Liked 299 Times
At some point, I started hoarding 110/74 cranksets.
If the other options don't work out I should have something(s), but I won't be able to dig thru until this weekend.
Likes For CO_Hoya:
Quoted: 502 Post(s)
Liked 466 Times
I have these two Ritchey Logic 110/74 cranks, but neither has rings. I’ve used these with 113mm and 118mm square taper BB, with a spacer under the DS arm to achieve correct chainline. They’re cold-forged, made by Sugino. Note that these use a hidden bolt behind the crank arm. The one with logos is 175, the de-logo’d set is 177.5mm. $45 each + shipping.
Quoted: 7348 Post(s)
Liked 2,471 Times
@phenry24 did you get what you need?
