How much faster are u on a 'bent that a std road bike?
Commuting Fool
Bikes: Raleigh Rush Hour (SS/fixie)
I'm have a fixed gear and a road bike that I'm very fond of, but I have never tried a recumbent.
I'm looking for speed and I think I'd like one of those long wheelbase dandies with the under-the-seat steering.
If I average 18 mph for a 100 mile century, would I be alot faster, assuming the course is pretty flat on a recumbent?
Practical Cyclist
Bikes: See my sig.
First off, don't expect to be faster right away. Recumbents use different muscles (or the same muscles, but at a different amount compared to a road), and take some time to get even as fast as you are on a DF.
That said, once you are well trained on a recumbent and comfortable, I would say on a flat ride you can expect to be anywhere from 10-20% faster, but more importantly, more comfortable. Of course if you are in something fared like a velomobile, the improvement will be even greater.
I unfortunately don't have a cyclocomputer on both my DF and my recumbent, but from some rough timing on my route (mostly rail-road grade slope or less) I know I'm typically faster on the recumbent, and much more comfortable, especially on longer rides. Aerodynamics plays a big part, but I'm sure comfort has something to do with it too.
Best way to find out for sure is to try it though, just don't judge off your first ride on the 'bent. Give it some time before the trials.
Edit: There's one thing I forgot to mention. Even though I am slower on my DF on flat areas, it feels like I'm faster. I attribute this to my face not sitting in the slipstream from my feet/legs/frame, and that it's pointing directly into the wind. Also, I'm sure there's less wind pressing on my body as a whole, leading to the faster time (but slower perceived speed) on the 'bent. Definitely take a cyclocomputer if you want accurate speed measurements, as your senses can be misleading.
Bent builder
Bikes: Magic leaning delta FWD trike, various bents and Fisher Sugar 3+
Yes, but the difference depends on the aerodynamics of each bike/rider combination.
But, to illustrate, the last time I had a road bike was about 20 years ago. I could max about 25 mph on level ground. I can do about the same max on my recumbent now. The difference is that now I have nowhere near the fitness and strength level I had when I was much younger and couldn't possible ride a road bike to the same speed. The recumbent let's my older body play to the same level as my young mind.
:)ensen.
:)ensen.
On a USS LWB you'd probably be slower. If you got a racing style recumbent, you'd be faster, although it's hard to say by how much. I have several racing recumbents. My former best time for a century on an upright, drafting for all I was worth, was 18 mph not including stops (avg speed on the auto-start computer.) I was pretty well wiped by the end. My best on a recumbent has been 23 mph, mostly solo, and non-stop. Well, non-stop except for having to wait through TWO cycles of the only light on the route! GRR! I was tired, but after catching my breath I walked several blocks and got myself a hot dog at a vendor stand.
Bikes: Trice Q; Volae Century; TT 3.4
On most days, I am somewhere between 14 and 16 MPH faster on a bent than on a road bike. My recumbents get used. DF's mostly pine away in the garage going zero MPH.
https://www.noping.net/english/
My experience is consistent with the results of this calculator. So, if you have an upright racing bike with your hands on the drops and can produce 200 watts then your speed is estimated at 19.8 mph. A highracer estimates out at 21.6 mph. So a high racer recumbent might be about 10% faster than an upright DF racer for the same 200 watt rider on the flats.
A low racer with above seat steering estimates at 23.4 mph.
shaken, not stirred.
Bikes: I've lost count.
Quoted: 1412 Post(s)
Liked 971 Times
I'm not actually any faster riding my titanium recumbent than either of my two road bikes. I'm just not as sore or tired after a long ride.
vBulletin: snafu
Bikes: Brompton H6, Schwinn Mirada, Cruzbike Sofrider. Used to own: ICE B1, 2 F-frame Moultons, Koga Myata Elevation 5000 mtb, Challenge Hurricane, Riese & Mueller Birdy Silver, Actionbent Tidalwave 3
Quoted: 14 Post(s)
I recently changed from a USS bike to a bike with tweener bars. I'm not sure there's much to the aero difference actually. If anything, my old USS bike had a terminal velocity going down hills several mph faster than my new bike, suggesting it may have been more aero. But hills aside, I'm much faster overall on my new bike because the position lets me generate more power, more efficiently.
To the OP: try to find a dealer and do lots of test rides. Recumbents have very varied designs, and some may suit you better than others. In general, to get the speed you're after you'll want to look for a high bottom bracket and reclined seat. Light weight would be nice too, but quickly gets expensive and a few extra lbs may not be a big deal if you're riding in mostly flat areas.
The other thing with speed questions is, at 10 mph, aerodynamics don't matter by a measurable amount. Ya gotta be going fast before aerodynamics matter.
Slower uphill. Faster downhill.
I'm averaging 14 MPH on my LWB recumbent.
Forgot to mention I ride a homebuilt recumbent in a hilly area. I might get a faster average speed in a flat area or with a commercially made recumbent bike with OSS. Who knows?
train safe
just curious, but why is a bent with under seatr steering slower than above seat steering, with both bikes being the same?
train safe-
train safe-
mosquito rancher
I'm not 100% sure this is so, but if it is, it would be a matter of aerodynamics. Aerodynamic drag is a function of two things: your frontal area (that is, how big a silhouette you present to the wind), and your coefficient of drag. Your Cd probably isn't much different either way, but with your arms in front of you, they are subtracted from your frontal area.
Adam Rice
Adam Rice
I really think the biggest bonus is the relax/rest factor on a reumbent, your normal sitting position is both exceedingly comfortable and aero. I would really suggest getting a LowRacer or HiRacer (or both).
LowRacers really can't be beat for speed and comfort on long distance, but I would consider them more of a loner bike. HiRacers just a step below in speed fit in very well with the DF crowd. I paceline with a group of upright riders quite a bit (allways in front or the back-never in between). Have done some 19 mph 100 mile paceline rides with my HiRacer. A 5 hour century this year on my LowRacer at age of 62.
Most USS are not designed for speed. They often have somewhat upright seating, with the bars below the seat. This increases frontal area, since the arms are essentially perpendicular to the wind (like an upright rider's legs.) Exceptions are bikes like the Reynolds Wishbone, which although they were USS, placed the rider so reclined that the arms ended up being in line with the airflow.
The biggest advantage for recumbents is comfort. For the racing 'bents, they also have the advantage of aerodynamics. A broad question like "how much faster are recumbents" ignores the diversity of the genre. If someone asked, "how fast is an upright?" the next question would rightly be "what kind - road, mountain, hybrid, cruiser?" Somehow, that eludes the upright community, who think a Carbent and a Bike-E are both recumbents, and lumping them together is perfectly valid.
Quoted: 111 Post(s)
Liked 5 Times
The bikes with under-seat steering are not as aerodynamic, because your arms catch a lot of wind that would be avoided by using above-seat-steering. Underseat steering is more about general riding and touring comfort more than speed.
The only currently-made underseat-steering LWB I know of (in the US) is the Longbikes Slipstream ($2800).
If you want a long-wheelbase that's fast, the $2600 RANS X-stream is an option (the top bike pictured).
High-racers are fast also and can be had for $1500 easily, but the steering is more-jittery. I had a short-wheelbase bike first and switched to a long-wheelbase, and very much prefer the longer wheelbase just for the steering stability.
There are also lowracers, but they mostly cost even more.
I have a 20/26" long-wheelbase recumbent by the by. I am probably slower on it than I would be an upright bike--but I am far, far more comfortable on the recumbent.
I didn't buy my first recumbent until I was about 35 years old.
If I'd have had recumbent bikes my whole life, I'd have rode at least twice the miles I did on "normal" bikes.
Bikes: RANS Stratus and a Mountain bike
On my LWB recumbent im 2 to 4 mph faster on ave. Also because of the comfort, I probably ride about 50% further. As stated the ASS LWB recumbents have a better aero profile. I myself adj my handlebars to keep my arms almost straight out so the aero proflie is just my fist. And of course the faster you ride the more advantage a recumbent will have since almost all of them have a smaller profile. Above 15 mph about 85% of energy used is to overcome aero drag.
Commuting Fool
So a SWB is faster than a LWB? What do "DF" and "high racer" mean?
getting bent
Bikes: 2008 Rans V3, 1984 Trek 620
If this comes thru properly then they are (left to right) (click on attachment to zoom in)
LWB (long wheelbase), MLWB (medium-long wheelbase), SWB (short wheelbase), not quite sure, highracer, lowracer, velomobile
DF is "diamond frame," a.k.a. UCI-compliant bike. We have other names for them, too; but "DF" or "upright" are the polite ones.
Racing 'bent come in two basic varieties: high and low. Highracers have two big wheels, 26 or 700c and very reclined seating. Lowracers are, well, low. Seat height is generally 13 inches or less, and also very reclined. Both types place the bottom bracket higher than the seat so that the torso is placed behind the legs (minimizes frontal area.) Of course, there is a smattering of 'bents which don't quite fall into those two categories, so you will hear of 'quazi-low' or 'mid-racer' or other variations.
