TBI from washboard roads?
Quoted: 1221 Post(s)
Liked 629 Times
Usually I can ride in a vehicle track and it's a little better. Also running your front tire lower would help. You're running tubeless right? Drop the front to 25psi from 35psi, and as long as it's not folding over itself in a turn you should be good.
As others pointed out your arms turn into suspension so don't death grip the bars, strengthen your core up a bit with situps and crunches. Still tough on me for fast, long rides! My neck is the worst.
Living in SC Kansas where sand is the primary product on the back roads, wash boards can go on for miles and miles. This is especially true when when we have extended dry spells. Instead of me going out and jumping on the gravel bike (marketing campaign) band wagon, I just continue enjoying my rides (45 miles yesterday) on my 10 year old 29er Trek Cobia all original. Getting ready to head out again in about an hour. Hands feel fine, butt feels fine, and my bike does just fine. I run 2.1's front and back, with tubes at 5 pounds over max pressure. Last flat was in 2019. Average speed yesterday was 15.4 mph. Fast over wash boards works for me.
Randomhead
Liked 3,698 Times
I can't understand why you would do this. Are you sure you aren't running your rims over max pressure? Stan's, as one example, has many rims that will only take 37psi with a 2.1" tire. They dont really specify what will happen if you exceed this, but I'm thinking they will split.
Also, you seem to have gotten lost from the MTB forum.
Lost from MTB forum? My 29er can be whatever I want it to be. It's my commuter, climber, racer, and road bike. ; )
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
What is the reasoning for running tires over max pressure on washboarded roads? I would think when you have such a wide tire as 2.1, you would want it to have less pressure to allow the tire to absorb more of the road imperfections.
Randomhead
Liked 3,698 Times
I see no reason to over pressure any tire or rim ever. There is a reason there is a max pressure, and higher pressures don't help anything. Mechanical losses will make up for any rolling resistance gains. Plus, I need to see a picture of miles of washboarded road. One of the roads I ride on occasionally has washboards on more of it than I would like, but it's a pretty steep downhill. Usually washboards happen where people brake
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 169 Post(s)
Liked 192 Times
I was thinking about this thread on my ride yesterday! Not a washboard road, but some pretty rough mountain bike trails. A few of the single-track trails were fairly fast but heavily potted, and there was just no way to avoid them. That was the most brain-rattling ride I've had so far. I probably should have let some air out of the tires (47mm tires at 30-35psi), but I'm not sure even that would have helped much.
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
This is going to come from way out in left field. Last week I did a gravel packing trip with three friends in northeast, Minnesota. We ran into many washboard roads. Oddly, I found that running them at speed was the best way of dealing with them. Granted, I was riding my Salsa El Mariachi with 2.5" tires, so had some float, but taking them fast, riding the crests, was so much better than riding them slowly. Sounds completely counterintuitive, but that was my experience.
Don't complain about the weather and cower in fear. It's all good weather. Just different.
Quoted: 169 Post(s)
Liked 192 Times
Likes For mattcalifornia:
Randomhead
Liked 3,698 Times
It's usually best to shift up one gear from where you would normally ride on rough roads. I'm not sure if that puts more pressure on your hands or not, but it mostly puts more pressure on your feet and off of your butt.
On roads with washboardish surface or alot of micro vibrations I usually pop into a bigger gear get my hands on the hoods loosely and stand up like I'm mashing a hill. I Let the bike drift and guide it with suggestion. Stay loose and keep - ass off the saddle.
Quoted: 286 Post(s)
Liked 262 Times
Unfortunately where I encounter wash board are the steep, twisty gravel roads. Hard to keep tension low in the body when you’re needing to brake and choose the best line. I’ve gotten better at this but I would flatten those roads if I could!
