First clipless pedal suggestions?
Bikes: Leader 722TS, Surly Steamroller, Panasonic DX-3000, Trek 4900
I've decided to put clipless pedals on one of my fixed gears. I'm trying to keep the cost of the pedals to around $50 or less. From doing some research it seems like the most recommended pedals are either the Shimano M520, Candybeater Candy, or Time ATAC Aliums. Should I just get whichever pedals I can find cheaper, or are their clear advantages to certain pedals? If it matters, I will most likely be using either Chrome or DZR shoes with the pedals.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 766 Times
I've used Shimano M520 SPD pedals for decades, and like them a lot. I use them on my road bikes, cross bike and mtn bike, or any situation where I need to walk or run in my shoes. You can get them for well under your $50 budget and they will last for a very long time. I see no downside to getting them.
One thing I meant to mention in my original post is that I have a history of having slight knee issues. Nothing major, but after years of running and riding bikes they ache a bit every so often. I've read that ATAC pedals are easier on the knees. Any truth to that?
Veteran Racer
Liked 766 Times
Maybe because the ATACs offer float and the SPDs don't ? I've never needed pedals with float and don't have knee problems, so the SPDs are fine for me. Nonetheless, my knees do get sore from time to time, but it's never severe and always goes away.
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
Bikes: 2014 Specialized Allez, Trek Farley, Trek Crockett, Deluxe Team dirt jump BMX, SE Draft, S&M ATF, S&M L.A.M.F., S&M PBR, BSD TrailOrPark, SE Vans PK Ripper
Quoted: 10 Post(s)
Liked 10 Times
I ride Eggbeaters. Very simple in and out. I have bad knees and these pedals don't bother me, actually cycling altogether doesn't hurt my knees it's everything else in the world that does. I had a pair of SPDs first but like the Eggbeaters better.
SPD's offer some amount of float. I have a dodgy knee and have no issues from using them for years.
I would second the M-520 suggestion, cheap and reliable, name brand so cleats will always be easily available.
LET'S ROLL
I've used SPD's for a few years now, like them a lot.
I said "used" because when my shoes wore out, I
decided to try Speedplays since my other shoes
are road Sidi's.
https://www.youtube.com/watch?v=FFyXxrqWbPA
are road Sidi's.
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Fresh Garbage
Some find that less float is better for their knees. But float is forgiving if you can't adjust everything just right (which can be difficult). You won't know until you try something. And I too would recommend you try the Shimano -- it's cheap, it's reliable, and if it works for you, you have something to stick with.
Bikes: Merlin Titanium serial #170 (29th road frame ever built, March '88), 1988 Cannondale Black Lightning, 2 fixed gear (46/17), Salsa El Kaboing fully mountain, Surly Pugsley modified
I use SPD's as well, and if you look around, the M540 can be found for less than $50. I tried the Eggbeaters and they were horrible by comparison, I ditched them cheap.
There are also two different cleats you can use with them, the 51' and 56's. The wife loves her 56's whereas I like the 51's.
old legs
the Candy Eggbeaters are annoying but the plain Eggbeater 1's are great once you adjust to them, simple easy and lots of float. I have ridden Shimano M424's and I think they are great...probably my next pedal.
I’m a little Surly
Bikes: Two Cross Checks, Karate Monkey, Disc Trucker, and a VO Randonneur
Quoted: 699 Post(s)
Liked 1,304 Times
People are predicable..
Egg beaters are great but to loose and riding in street shoes on them is "interesting"
Time is expensive and over rated IMHO and limit your shoes
If I were you I'd just go get some LX/STX SPD's some vans style shoes and call it good
If you must be roadie get some entry level looks and what ever shoes are in sale.
sɹɐʇsɟoןןnɟsʇıbɟɯo
Bikes: fixed gear recumbent trike
i can't ride ATACs cuz i need lateral cleat adjustment.
but I LOVE HOW ATACS FEEL.
when i do ride two bolt cleats, they're eggbeaters, and i hate them. so loose, so sad.
Successful alcoholic
Quoted: 21 Post(s)
I love my Eggbeater Candys, as well as a set of discontinued Quattros, and I don't find them loose at all. People I know who complain about looseness with them tend to have horrible pedal strokes, especially when sprinting or when tired. Their feet flap all over the place, so they tend to need a more secure pedal. I spent several years on Speedplay Frogs, so the Candys feel like bear traps to me.
crazy keeper
Bikes: Concorde Track bike, Cramerotti Track bike, Brodie Unibomber, Concorde Road bike, Concorde Time Trial, Babboe City Bike
Try out the Shimanos. I still have a pair of 737s that are rock solid and I rode them for years. Great pedals.
Quoted: 89 Post(s)
Liked 15 Times
Nashbar often has Shimano pedals really cheap. Right now m520Ls are $26.99, m540s are $43.99 etc. My first pair was the m780s ($72.99) and have put several hundred miles on them with no issues. You basically forget about them once you get the hang of it.
