What else would work with 10s Dynasys?
I hate to ask this question, but I'm looking at putting drop bars, or some other multi position bar, on my commuter bike to use it for a longish tour. The problem of course is the levers and shifters. The bike is set up with XT 10sp Dynasys derailleur, 10sp 11-34 cassette, and Deore dynasys 10sp shifters. All work beautifully together. Shifting is the very light touch that Dynasys promised. I also have XT v-brakes on it with Deore levers. The front uses the original 7sp XT derailleur and that works just fine the way it is. I had replaced the large chainring as the chain would slip on it but it didn't do that on the middle and I never use the small. It all just works and I've been riding it for about 8 years that way.
I've already figured out the levers, Tektro RL520 levers are specifically made for v-brakes on drop bars. But what about shifters? Is there anything else compatible with 10sp Dynasys? I was just reading that 11sp is almost compatible, but what is available in that even? I'm just looking to get ideas, not necessarily going to change the shifters as they could still be mounted on a drop bar, just not conveniently placed. I didn't see much when I googled, just some downtube shifters from Dia-compe. Anything else?
Quoted: 1088 Post(s)
Liked 1,025 Times
Microshift will get you 10sp and 11sp dynasys shifting in the brake levers and probably have other shifters as well.
Likes For Russ Roth:
I just looked and they offer a 10sp Dynasys brifter but only right/rear side, the left is brake only. The other thing is that the brake levers are short pull only. I need long pull.
Gevenalle makes just what I'm looking for, at a price of course. The have 10sp Dynasys/3 front and linear pull levers all in one! Thanks. It is definitely a more expensive solution but still a lot cheaper than buying even a used bike for the trip. All good except they are out of stock, but the trip is next summer so maybe not a big deal.
Expired Member
Quoted: 3674 Post(s)
Liked 5,433 Times
Doesn't Microshift have bar end shifters for Dynasys? You could use whatever brake levers you want. Or use a "Trekking" bar and keep all your components.
Quoted: 1944 Post(s)
Liked 2,164 Times
Once upon a time…
WTB made shifter pods for dirt drops that allowed the use of bar end levers mounted close to the brake levers.
You will most likely never find them, but if you have access to a machine shop and a bit of ingenuity, you might come up with something.
The Gevenalle is probably your best bet, but I thought I would throw this out.
John
John
Quoted: 2026 Post(s)
Liked 1,096 Times
Kelly TakeOffs were very similar and allowed mounting bar end or downtube shift levers adjacent to standard dropbar brake levers. I used them for a while and found them a bit awkward. Once I discovered Gevenalle there was no going back. They are a far superior design.
Quoted: 4206 Post(s)
Liked 3,870 Times
The only thing I have to add is that most all tourists that I know that tour find lower gearing then what the OP usually rides in will be needed. I suspect the OP will use that middle and if in a hilly area the granny rings. Andy
AndrewRStewart
AndrewRStewart
Liked 1,025 Times
They do offer thumb shifters, rear 10sp mtb front double or triple friction so it won't care what your der is.
https://www.universalcycles.com/shop...s.php?id=74328
I have found their brifters can be bought in single side and would just get the front if I needed that, mixing and latching doesn't matter, their levers all look virtually the same unless you get their series line. V-brake pull is a problem and I even find that the newer road levers, for all the claims, still suck with v-brake. Travel agents help a good bit but I'm switching my tandem from V to canti for just this reason.
I don't see the value in thumb shifters over the Deore shifters I already have but maybe I'm missing something. I like the way the Deore shifters work with a very light touch and I'd sooner leave those on the bike even if not conveniently placed. I'll have to find a hand position where they can work. The Gevenalle are a different story, putting a road feel on an MTB
Liked 3,870 Times
NYC has hills?
My tour from Rochester to Boston averaged around 9mph. Along the flat (by most anyone's standards) Erie Canal route it was about 11mph but the Berkshires dropped that a lot. Andy
AndrewRStewart
AndrewRStewart
The Microshift 10s bar end shifter made for Shimano mtb duty works fine on my S&S coupled travel bike with a Deore RD. On the left side almost any friction shifter works for front duty. In fact, I currently have a seat tube shifter for the front triple crank to eliminate cabling across the couple and speed frame breakdown.
The ride I'm doing is actually the Empire State trail so that includes a lot of the same ride. I ride around the Berkshires too but never found it too bad.
