Saddlebag Alternatives
Does anyone carry their tubes, tools, etc. in something other than a saddlebag on their road bike? I'm looking into trying something different because the rear blinky that I use won't mount properly with a saddlebag in the way. Any pictures or suggestions would be much appreciated!
P.S. I'm a very casual roadie--probably riding about 30-50 miles a week.
Quoted: 1332 Post(s)
Liked 398 Times
Handlebar bag, or saw off the top of a water bottle and throw your stuff in there to look super pro.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Many saddlebags have a fabric loop onto which your tail light can clip. What light and saddlebag do you have?
Quoted: 1217 Post(s)
Liked 187 Times
Got rid of all my saddle bags a couple years ago. Now I use small frame bags. Lil' Dude from Ellum Bag Works is a good one and I like the revelate jerry can for mtb.
https://ellumbagworks.com/product/lil-dude/
https://www.revelatedesigns.com/index.cfm/store.catalog/Cockpit/Jerrycan
https://www.revelatedesigns.com/inde...ckpit/Jerrycan
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
Quoted: 212 Post(s)
Liked 83 Times
Many lights will also mount on the seat stays. Some even come with the necessary hardware.
Also, while i do use a saddle bag, my pump is secured beloe the down tube. Depending on frame geometry that may be an option for you. There are bottle storage containers. Could you zip-tie a bottle cage below your downtube? I even used to have a bike with water bottle bosses below the downtube. I miss that bike.
Non omnino gravis
Thanks! I'm going to look into this.
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I have one of those little dudes mounted on the rear of the seat post for my little tools and patch kit. The hand pump is on the top bar. I have 2 blinking lights mounted facing rearward, 1 on the rear of my rack and one mounted directly beneath the seat with a custom bracket that fastens to the seat mount. I should mention that the light under the seat is obscured frequently when hauling extra gear, hence the second one on the end of the rack.
When I outfitted a couple of bikes for patrolling mountain trails I included the little dude style packs and all anyone ever used them for was snacks.
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
Take a standard Bontrager FlareR rear light (fairly popular from what I've read), they supposedly have 270 degrees of visibility. Is it really a thing that if it's not firmly pointing in a single direction (which is where?) it's not effective?
Quoted: 980 Post(s)
Liked 776 Times
Unfortunately, I only have the two bottle mounts (seat tube and down tube), and to make matters worse, I don't have enough clearance between my second bottle and top tube to mount a bag. I've also tried different types of lights, but they really don't have quite the same effect as seatpost mounted lights, at least in my opinion.
Plenty of clearance if you drop the second bottle.
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
I've lost 2 expensive usb taillights off them when they rattled off on bumpy descents. Nowadays I mount my taillight under my saddlebag. All my bikes have enough seatpost showing that there's room for both.
Quoted: 4560 Post(s)
Liked 2,802 Times
No problems with my Cygolite Hotshot or Blackburn 2'Fer taillights sagging or popping off my small and medium Serfas Speed bag under-saddle bags. The lights don't weigh much and have snug clips. The 2'Fer has a retaining nibs so it's more secure than most, and more versatile -- it has red and white, steady and blinking modes in a single unit.
I've loaned my lights to other folks during group rides and so far my lights haven't popped off anyone else's bags either. So far all of the stray taillights I've retrieved on group rides had the smooth metal clips without any retaining nibs, or the rider tried to clip lights to their shorts, jerseys or some makeshift thing that didn't work and endangered riders behind them. Same with those makeshift flashlights with rubber bands that always pop loose on rough roads and railroad crossings.
I also have seat post mounts so there's another option for securely mounting lights. I've never had a light pop loose from those.
Usually I mount the Blackburn 2'Fer on the back of my helmet. I prefer having two lights, front and rear -- gives drivers a little more help in determining distance, direction and relative speed. I use the original Blackburn strap mount on one helmet and a generic rubber strap on the other helmet. Both are secure.
The only taillight that's popped off my Serfas bag was a Planet Bike Rack Blinky 5. It's larger, heavier with two AAA batteries, and the plastic clip doesn't close tightly. But it's fine on the two mounts provided for a rear rack or seat post.
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
Depending on the type of ride: try the hiker's bag, the waist pack or also known as the lumbar bag.
The back pocket of the typical bike jersey, when filled with contents, resembles the lumbar bag.
There are different sizes of lumbar bags/waist packs. Whatever you need to pack your items.
Its a reasonable alternative, but for the fashion conscience, maybe not that much.
The pros: holds more stuff than a saddle bag; anti-theft because its on you, unless you get mugged; frees up your bike frame because you're wearing it; jersey pockets not primary space; on hot humid days, lumbar region doesn't feel the heat.
The cons: not fit for racing; access to energy bars, cell phone, keys become cumbersome; not fashionable.
This is something you at least may try out. You can always use the hiking bag for hiking anyways. REI has an assortment. Again, it depends on the type of ride for that day. For most recreational riders, its not about racing.
Quoted: 20810 Post(s)
Liked 9,456 Times
If you can't fit your flat/mechanical kit in your jersey pocket, you might want to reconsider your kit (if you don't have a jersey pocket, you might want to reconsider your attire). And, as has been mentioned above, you should also be able to get by with one bottle, opening up the other bottle cage as another storage option (during one-bottle weather, I use an REI/Co-op-branded container).
Bikes: Corvid Sojourner, Surly Ice Cream Truck, Co-Motion Divide, Co-Motion Java Tandem, Salsa Warbird, Salsa Beargrease, Carver Tandem
Quoted: 534 Post(s)
Liked 435 Times
I use a fanny pack. Works for me.
Thanks for all the suggestions so far (except the one about not drinking water)! Looks like I have a little product research to do. I really like that LG bag with the light built in. I think that's a front runner for me.
