Defective NOS parts
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Defective NOS parts
Here's an interesting problem. We prize NOS and nearly NOS parts, the ones that haven't been manufactured for years and have, somehow, survived in new or nearly new condition. Right?
Well, one of the reasons parts remain NOS is that they were defective to begin with.
Consider, for example, the black Bluemels Club Special fenders I bought on ebay a few years ago. They're not NOS, but they're in great condition. There's just one little problem, which you can see here:
A fender mounts to the fork by a steel piece that is riveted to the plastic fender. But the steel piece is a good 1/8" off center.
Minor defect, but it's impossible to mount this fender well. It's invariably off center somewhere. And a bit twisted.
So... how would you fix this?
And what other strange defects have you found in NOS parts?
Quoted: 3811 Post(s)
Liked 6,711 Times
I'd drill out those rivets and use a different bracket or fork crown daruma.
Neal
Neal
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
FBoD Member at Large
Quoted: 30 Post(s)
Liked 7 Times
Funny, the bracket looks centered on the fender based on how much fender is left on either side of the bracket. However, the bracket doesn't line up with that center ridge in the fender. Looks like that center ridge is molded screwy to me.
Dropped
Agreed. And you haven't bolted your bracket vertically square.
multimodal commuter
Liked 574 Times
Yes, that's because of the twist. Mounted square, wheel hits the inside left front edge of the fender.
I think the off-center bracket is the primary problem, and in turn caused the twist. I'll probably fix the bracket the way Neal suggested, though I'm not sure what to use for rivets. Once that's done, I'll try to remove the twist. I think if mounted properly and left in the hot sun, the fender will gradually take its correct shape.
I got 99 projects
Quoted: 42 Post(s)
First drill out the rivets. Then drill new holes in the fender, slightly forward or aft of the old holes, but close enough so the bracket will cover the old holes. Use a small piece of flat steel or aluminum on the underside to reinforce the new holes since they'll be close to the old holes. Then just use a couple fat pop rivets or bolts like these to put it all back together.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Yes, I do believe that a good number of "NOS" items sold today were most likely called "seconds" by our LBSs when they were new. Ran across one myself recently. Some of them might even be a collection of good parts put together from maybe defective components, Heck if it was put together well, looks great and works, there's nothing wrong with that as far as I'm concerned. As long as it's not overpriced.
Chombi
Chombi
Bicycle Repair Man !!!
The black Bluemels are rarer as they tend to be far more fragile than the white ones... have seen one nice set of black ones while I run across a lot of white Bluemels that tend to be in far better shape.
Pants are for suckaz
Bikes: Hardtail MTB, Fixed gear, and Commuter bike
How about more rivets? https://www.harborfreight.com/hand-ri...set-38353.html
multimodal commuter
Liked 574 Times
multimodal commuter
Liked 574 Times
Yes, I know something is very screwy here. The bracket is off-center. The fender is twisted. And from looking at a macro photograph taken from only a few inches away, with all the concomitant foreshortening, it looks like the plastic extrusion is also asymmetrical. That would explain a lot, and you may be right. I don't think so, but I will indeed check.
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
"There are no trash cans on a production line". Parts that are not perfect are
Still sold. It's the only way the part can be warrantied, if it's thrown away the manufacturer takes an immediate loss.
Quoted: 30 Post(s)
Liked 7 Times
It looks like they centered the bracket properly but that molded ridge isn't centered. That twists the fender against the bracket and it goes to the right which is why you have to mount it to the left to get it centered over the tire but then it's not centered in the fork.
Fenders, the most frustrating accessory we deal with I think
Quoted: 3464 Post(s)
Liked 2,831 Times
Liked 4,396 Times
No one cares
that reminds me, if you purchased a 1995 Chevy Beretta or Corsica there is a small chance a few of your driver side dash bolts werent installed properly. Sorry about that.
Of course, if you own a 1995 Beretta or Corsica there is a good chance it's sitting in your back yard on cinder blocks and it has huge pieces of Dupont paint missing from it.
that's all I have to add except that I'd re-rivet that fender. I have a few rivet guns.
I prefer emails to private messages - holiday76@gmail.com
Jack Taylor Super Tourer Tandem (FOR SALE), Jack Taylor Tour of Britain, Px-10, Carlton Flyer, Fuji The Finest, Salsa Fargo, Santa Cruz Tallboy, Carver All-Road .
Bikes: Many
Quoted: 5 Post(s)
Liked 10 Times
The "nail" in the rivet has a small flaw that causes it to fail in a certain place on the nail. Choosing the correct "grip range" will prevent exposure of the remaining piece of the nail. Rivets come in several different types, sizes and materials. I would say, 1/8" X1/8" (diameter of hole/grip range) aluminum nail with aluminum dome head rivet, perhaps a large flange. This the most suitable product for the application from what I can tell from the image. Steel/stainless nail MAY have to high of a threshold and bust the plastic.
RV stores often have small quantities available of high quality POP brand rivets.
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
I was engineer on a ship that the owner/captain was getting ready to sell. It had one of the first computerized autopilots and the thing didn't work right from the very first. I won't bore you with the laundry list but the problem I had to face was that the electronic compasses "fade" after years whether they sit on your boat or on a shelf. The loal rep said he had 3 of those compasses on his shelf, NOS and he's sell us one for $300 but he was pretty sure it wouldn't work any better than the one we had.
Then my contract expired and it was the next guys problem.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Campy 1010B dropoout, faces machined, drilled and tapped for Portacatena, but never stamped with "Campagnolo."
Liked 4,396 Times
multimodal commuter
Liked 574 Times
