noises coming from my chain
Bikes: Civilian Le Roi Le Veut, Kazane Track, Ciocc Designer '84, Serotta Colorado AL 25th anniversary, '85 Guerciotti Pista, '84 Trek 660, Volume Credence
hey, so i just switched over to a fixed gear a few days ago, and sometimes when I am riding, there is a bunch of noise coming from my chain. it sounds like the gears are changing, even though there arent any. when i get off and look at it it doesnt seem like anything is wrong, the chain tension looks fine and the chain isnt falling off or anything like that. Before when i was riding it single gear i did not have any problems with the chain making noise and i had the same setup, just with a freewheel and not a fixed cog. I think it might be because my front chainring is 3/32 while my chain is 1/8 inch. Or does the chain length and tension on a fixed gear differ from that you would use on a single gear? any help or ideas would be nice. thanks
OASAASLLS
Bikes: Pake, Surly Pacer, Kilo TT, Giant XTC, SE Stout, 853 Ritchey MTB
Have you tried lubing the chain to see if it is dry?
okay, i will try lubing my chain and see if that makes a difference. and so i'm guessing the chain tension doesnt change from single to fixed?
sniffin' glue
Bikes: Surly crosscheck ssfg, Custom vintage french racing bike, Bruce Gordon Rock & Road
it is a conversion. but with new cogs
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
Prolly too tight...
Your cog is slipping.
