Paint removal? Latex? Oil base?
So I picked up this Nishiki Westwood. Someone painted it with something. The first layer of paint was green watercolor...seriously...and came off easily. Now there is this white/blue paint layer on some parts. Might be latex. I dunno. Mineral spirits removed a small part but it took some work and to do the whole frame would require an awful lot of work. So what can I use to remove that paint and save the silver paint underneath?
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Get this, household latex is removed by isopropyl. Even cured! When I was correcting the issues with the Kona, I wiped the paint off of a fork leg while cleaning the frame for a splatter run, with a paper towel wet with isopropyl.
If it's spray paint, Acetone and some rubbing will help remove it without harming the finish underneath too much. Acetone is great for removing spray enamel, but not so much production paints or urethane finishes. You might have to use some polishing compound after acetone to restore a hazed topcoat.
Try Isopropyl first, and if it budges, it's a water-based latex. If not, try Acetone. Since the tubing decals are over the topcoat (if the bike had one) be very careful with both of them around those. Brand decals might be under a topcoat, but use caution unless you're sure.
Likes For Unca_Sam:
Likes For Jicafold:
The dropped
Liked 1,014 Times
Another happy ending!!
Likes For Unca_Sam:
Bikes: 2022 Specialized Creo E-Bike XXL with Custom Wheels, 1992 Serotta Colorado II with Dura Ace STI, 2021 Zinn Ti Clydesdale Team XXL with Ultegra Di2
Quoted: 54 Post(s)
Liked 39 Times
Paint stripper
methylene chloride if u can find it
The dropped
Liked 1,014 Times
Quoted: 54 Post(s)
Liked 39 Times
Yes, sorry...didn’t read the OP’s question all the way through
aka Phil Jungels
Easy Off Oven Cleaner works wonders on added on paint! Experiment with it on an unobtrusive part first.
