new manufacturers of hoses for vintage frame pumps?
Fuji Fan
I've got maybe 4 bikes that have old vintage frame pumps, but all of the hoses are for schrader valves. Are there any new manufacturers that make presta hoses? I see some used ones on Ebay, but I would prefer newer rubber if possible, given I don't want to get stranded in the middle of nowhere.
The alternative that I have used are presta valve pump heads that thread directly on the other end of the pump, as shown below. The part that irks me is that the pump peg is kind of small compared to the schrader hose end.
If I am stuck with continuing to use those old pump heads, are there known sources of new rubber for the ones that are cracking?
Quoted: 3814 Post(s)
Liked 3,345 Times
IIRC Mel Pinto may have NOS frame pump hoses as produced by Poutrait-Morin, Etablissements Jeunehomme & by ALGI
Quoted: 4513 Post(s)
Liked 6,388 Times
Will likely take some creative hacking to attach the ends so the hose goes into the pump like normal or you may have to carry the hose separately.
Or you can buy this for the hose that should fit.
https://www.ebay.com/itm/39331289633...BlBMUIaJucH2YQ
Fuji Fan
You should be able to find bulk hose to cobble onto the fittings of the old hose.
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
this is a tall order. might you be able to find a hydraulic supply house in your area
probably over kill but they will know about swedging pressure hoses
just a thought
/markp
just a thought
/markp
Likes For mpetry912:
Liked 6,388 Times
https://www.ebay.com/itm/12261623930...Cclp%3A2047675
Likes For merziac:
Fuji Fan
Here's the presta version or you can add an adapter.
Likes For beech333:
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,480 Times
Brent
"I have a tendency to meander sometimes." B.G.
Liked 3,345 Times
now that the presta hose hath been sorted...
all we need is for someone to come up with a request for a Woods...
Bikes: Indeed!
Liked 3,480 Times
Try Yellow Jersey cycle in Arlington WI. Phone calls work best, his web site is "challenging".
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
Zefal still make them . I have a couple of each that I bought recently locally for no money at all ( brand new for $3.00NZ ) schrader or presta ( Isnt woods the same thread as presta ? )
