Nipple Washers
Quoted: 1858 Post(s)
Liked 664 Times
Nipple Washers
I see some nice cupped Sapim nipple washers on line, and I’m planning to build some wheels with rims which do not have ferruled spoke holes. Anybody tried these?
I have no problem with either stainless or brass flat washers but these Sapim look more suited to the purpose.
What do you think about these?
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
As I understand it the pro's rarely use them, so that should tell you something right there. I suppose if the rims in question have a history of cracking at the spoke holes then the washers may help. What rims, how many holes, what spokes, what riding conditions, and how much do you weigh?
Liked 664 Times
Rims are urai, 630 mm bsd, 36 holes, no ferrules, 3x, beads not hooked. Riders are 180#, average 12 mph on MUP, hubs are large flange, original aluminum shells, OLN will be 123 mm (5 speed).
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Eyelets, not ferrules. On aluminum rims it can't hurt to use them. I mainly use them on carbon rims, the cupped ones fit really nicely in rims that have an aero section.
Quoted: 4210 Post(s)
Liked 3,878 Times
I suspect these rims are from the later 1970s or early 80s, the 630 bead diameter and the lack of hook edges are the tells. If they are what I think then they were never laced with nipple washers, IME. I also suspect the spoke bed is thick enough for not needing washers for reinforcement reasons. Andy
AndrewRStewart
AndrewRStewart
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Hard anodized rims have a brittle surface layer, that once cracked can progress to failure. Nipple washers can reduce the likelihood of a crack forming and thus prevent this type of failure, or at least prolong the service life of the rim.
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
Nipple washers may help reduce binding when reaching full tension values. Might help with rim cracking, but maybe not. Bill Mould has a lot of experience with this stuff and his investigations have determined that rim cracking is usually due to low-tension issues usually found on traditional rear wheel non drive side spokes. Here's a great YouTube video of his:
If I were wanting to reduce the chance of this happening, I'd use butted spokes and a calibrated tension gauge and make damn sure spoke tensions were at max (usually 120kgf, but depends on rim & hubs being used).
Liked 664 Times
