Campy Centaur VS SRAM Force 22
I just acquired a vintage frameset (1985 Mercian) and I am trying to decide on components.
The options are Campy Centaur or SRAM Force.
In 2015 I built up my current bike which is a Cannondale EVO using Campy Chorus 11 speed.
I never could get the shifting to work properly. I tried different chains and cassettes and took it to a pro mechanic but still no luck.
I have read that Campy shifting can be sensitive to cable friction but i have no reason to believe that here was excessive cable friction.
In the end I changed to SRAM Force and it worked perfectly. I am not saying Campy is inherently flawed, just that it did not work in my case at that instant of time.
So I am willing to give it another chance, mostly because it will cost $150 less than SRAM Force and I get silver components.
Being that it is a vintage bike I think silver Campy components would be more appropriate and I will be using a Campy crankset although it is carbon and black.
I plan on building wheels using H Plus SON silver polished rims and also would like use silver Campy skeleton brakes.
The Centaur components weight 142g more than SRAM but I can live with that.
My brain is telling me to go with SRAM since I know I like how it works and I would have consistency between bikes, but my gut is saying Campy for a classic look and my wallet would also appreciate it.
Thanks for any advise.
Expired Member
Quoted: 3674 Post(s)
Liked 5,433 Times
I think Shimano 7000/105 is still available (theoretically) in silver. Might not look as cool as the Campy but you wouldn't have issues.
Likes For shelbyfv:
Regarding the OP I've had Campy on multiple bikes and it always worked well for me so maybe your experience was just an outlier. Maybe to relieve stress just go with what you've used in the past that worked well.
Likes For TX_master:
Likes For jnbrown:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I love these threads...OP askes 'Campy or SRAM?'...first 2 replies are Shimano.
Expired Member
Liked 5,433 Times
Yep. Around here you never know if someone has overlooked the obvious.
Likes For shelbyfv:
Le savonnier
Bikes: I can count 'em on one hand
Quoted: 729 Post(s)
Liked 602 Times
SRAM Force. In choosing the groupset for my upcoming Hampsten Strada Bianca, I initially thought Centaur, because I could get it in silver. But I wanted something in the Chorus/Ultegra/Force upper echelon groupset realm. Then I got over the silver thing, and thought I'd go with Ultegra. But I remembered how much I disliked the Shimano shifting method. Then I got to talking more about it with Steve (Hampsten) and others, and they all said, one way or another "Go with SRAM Force, you'll be glad you did."
Part of the decision also rested on the fact that I have never used SRAM products, and wanted to give them a shot. I'm looking forward to it.
It doesn't take long getting used to double tap shifting and I like having a single shift paddle.
The one thing I still have trouble with is shifting the front from the small to large chainring, you have to give it a nudge at the end of the throw for it to stay there and it takes a subtle touch to get it right.
Also sometimes the shifting is a bit rough when shifting under load especially on the larger cogs in the back, but I think that is true for other systems as well.
Now I have to wonder if I can get over the silver thing too.
Likes For jnbrown:
Le savonnier
Quoted: 729 Post(s)
Liked 602 Times
I understand the aesthetic thing with silver components, I really do. I have traditionally been a C&V guy. But I have other bikes for that. And besides, I don't spend much time staring longingly at my bikes, particularly while riding them. It's about performance for me. I have cleared out all but two of my C&V bikes, partly to help finance the Hampsten, partly because of space, and partly because I'm just plain tired of dealing with all of them, when I only really ride two of them. I wanted to go thoroughly modern (albeit still steel and rim brakes; not quite ready to make the carbon/disk jump!).
Also thought this:
Campagnolo = old-school, tradition
Shimano = the 800 lb. gorilla
SRAM = the upstart underdog
I'm a sucker for the underdog (however true that may or may not be in SRAM's case).
Also thought this:
Quoted: 2026 Post(s)
Liked 1,096 Times
Actually, as you said Shimano is still the 800 pound gorilla but SRAM isn't the underdog anymore, Campy is. AFAIK, SRAM outsells Campy by a substantial margin.
Likes For HillRider:
One thing I have noticed in looking for SRAM shifters there is only one listing on Ebay for used ones.
I think that tells us people are generally satisfied with them.
If I really wanted this bike to be vintage I could put old Nuovo Record on it but that is not what I want.
I thought I could straddle classic and modern but I am thinking I should let that go.
Likes For jnbrown:
Bikes: lots
Liked 2,932 Times
If you go with SRAM I'm pretty sure you'll like it. It's pretty easy to set up and is also tolerant of being slightly out of 'perfect' adjustment. It rarely fatigues/breaks cables in the shifters like both Shimano and Campy do. Your wheel choices aren't governed by free hub design. It's good stuff.
Likes For cxwrench:
For sure my preference is Campagnolo. 3 years ago I installed, for the first time on my own bike, indexed shifting. Since 1982 I have worked as a mechanic, sales person and manager in bike shops and have experienced every level and generation of indexed shifting and developed some knowledge and preferences for equipment. My choice was Campy 11 speed at the Record/Chorus level.
Just moved the group set from my custom frame to a vintage frame and it works perfectly on the first try, just like it did when I set it up on the custom frame. I do not find it finicky or picky about cable drag, but I do know that it does perform with more consistency using Campy or Shimano brand housing.
I have set up thousands of bikes with every drive train option from the big 3 (soon to be big 4 with Microshift coming on strong), and have had to teach users how to shift. SRAM is the most confusing, Shimano is frustrating for newbs when they shift the big lever, and Campy is the easiest to teach as the lever functions are independent of any other function.
Now, with all that said, I am not a fan of SRAM. For newbies it is difficult to learn to use, and for experienced riders it simply is not intuitive. I also find it finicky and sensitive to dirty cables. FWIW, the Apex shifters are cheaply engineered and made. Without question Shimano is the most forgiving when cables are dirty. Campagnolo is my personal got to, and the first thing I recommend when someone wants high end and high performance without budget constraints.
Likes For TiHabanero:
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
Quoted: 1562 Post(s)
Liked 1,734 Times
Use the Force Luke. The SRAM group set has the YAW front derailleur so you don’t have to trim. Just for that reason alone the SRAM wins.
But if I were you I would choose neither and go with your original inclination and find an all silver group set.
Likes For icemilkcoffee:
Cxwrench, I applaud your willingness to work for a pro team. Not many folks want that life, good on you! No doubt your experience is superior to mine which has led you to the SRAM preference. To each his own, and the OP asked for opinions, which is what has been given by all.
Thanks for all the responses.
It really helped to make a decision which is to go with Force 22.
I am still going to use silver where I can which would be wheels, headset, brakes, bars. seatpost.
I think will still have a bit of a classic look to it.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I like both SRAM and campy well enough that for me it would come down to which I liked better on the bars I planed to use.
Campy is 11 speed only at the lowest level and SRAM's support of 11 speed mechanical is questionable. If not used on lower priced OEM bikes, those groupsets won't be around much longer. I built bikes with every speed of Campy from 8 to12. I switched from Campy chorus 12 to SRAM Force AXS last July. On a rim brake bike, the crank, brakes and wheels were used with a new freehub body.
I'd look at SRAM Rival AXS. It's been noted that when Shimano 12 becomes available, there's a good chance that the cassette will work with Rival and most 11 speed cranks, but Force levers would be needed for rim brakes.
