How to adjust adjustable road stem?
Senior but far from AARP
Bikes: 2006 Specialized SWorks Tarmac; 2005 Bianchi Giro; 2005 Bianchi Cross Veloce; 1997 Litespeed Catalyst; 1983 Performance Steel
https://www.performancebike.com/shop/...4&PID=1684032#
Cannot get adjustable road stem to "adjust"
No instructions came w/ it.
How much force should I place on the adjustment to rotate. Tried fair amt of force, and no dice.
Bikes: 2003 KHS F20-Westwood folding & enough parts to make several more bikes...
I'd disassemble it and figure out what made it tick before putting ANY force on it.
LF for the accentdeprived
I'm guessing that the two surfaces are serrated inside, so you have to loosen the bolt and possibly gently pry them open. Ihope they're heavily serrated because otherwise there's no way they'll hold up. So yeah, remove the screw and see what it looks like. Not rocket science.
Quoted: 1572 Post(s)
Liked 643 Times
Look at the underside of the stem. There's probably a little finger hidden under there that you have to nudge out of the way before the stem angle will change. Be sure to push it back in or it won't stay where you set it.
TWilkins
Ditto on looking underneath. My wife's bike has an adjustable stem, and it has a bolt underneath holding the stem into a serrated finger that keeps it from slipping.
Quoted: 383 Post(s)
Liked 690 Times
Had to be completely disassembled, then one side PUSHED out of place, not pulled. Sorry, hard to explain. Thanks.
