20 inch wheel , 75 mm hub, 28 spokes, 1 inch rim width
Hey Bike Forum peeps, I work at a non-profit bike shop. We received a donated Btwin foldable bike with a bent rim. Decathalon won't replace the wheel and they don't sell replacements.
The 75 mm hub is non-standard. No one seems to be able to order a replacement wheel. I need a 20 inch wheel with 75 mm hub width, 406 bead diameter, exterior rim width 1 inch.
I'm told we can build a wheel, but this is a 28 hole rim, also non-standard.
Any ideas where I can order wheel or rim with the above specs?
This is for a front wheel.
TIA
TIA
Really Old Senior Member
You can't economically save every bike.
Even if cutting off and rewelding the existing dropouts were possible, it raises liability issues you're best off not to take on.
Sometimes you have to know when to punt.
Likes For Bill Kapaun:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
^This^. I have no problem telling people it's either too difficult or not worth it to fix their 'project'.
Likes For cxwrench:
Quoted: 428 Post(s)
Liked 1,014 Times
Have you looked for a replacement rim? Maybe through a BMX supplier? I believe the Sun CR18 used to come in this configuration, haven’t checked in awhile though.
TIA
TIA
https://www.ebay.com/itm/195249931414
Also found this 20" 28H wheel with a 70mm hub. It's for a stroller/jogger, no idea if it's strong enough for bike use or not. Dunno the rim external width, and also dunno if the rim would be suitable for clinchers or rim brakes. I'd be leery of using it on a bike.
https://www.ebay.com/itm/143673459221
I have not done business with nor do I have any commercial interest in either vendor.
This vendor does seem to have the Sun Ringle CR-18 referenced above available. I have done business with this vendor; they seem reliable. I have no commercial interest in the vendor.
https://www.ebay.com/p/5012039443?iid=374136270038
BSD isn't given in any of those listings. You'd need to contact them to see if they're 406, but many BMX rims are. No clue about the stroller/jogger wheel.
Thanks all. Unclear whether it's worth time/effort to save this bike. The Sun Ringle seems the choice if we're to build a wheel. But, a wheel build is likely to be outsourced. I'll check with our team. Thanks again.
I am potato.
Quoted: 1826 Post(s)
Liked 1,704 Times
Off the cuff, it sounds like the front wheel from a Dahon or a Brompton. Dahon has a 9mm axle, Brampton has an 8mm axle.
When I re-did my Dahon, I picked up a Shutter Precision Brompton dynamo. Then I obtained a length of 3/8inch stainless steel brake line from an auto parts store. I cut 2 short sections off the line to be collars & pressed them onto the exposed Brompton-sized axle nubs with the tiniest bit of JB Weld. The effect is a the proper 9/9.5mm-ish axle diameter a Dahon fork drop out expects. (Going from memory, here.)
I wouldn't do the above hack if cup/cone bearings were to be used. Shutter Precision dynamos use non-serviceable cartridge bearings & are regarded to be just about disposable, so it's no big loss should a replacement be necessary in the far future.
Alternatively, going the other way, I would expect you could file the Bromptons dropouts to accept a Dahon wheel. You might amend your search along these lines.
Velocity makes 406 Dyad rims in just about any drilling you could want.
Also, I may have a full Dahon wheelset or suitable front at my Co-Op. bike_forum_geek PM if you hit a dead end.
Quoted: 458 Post(s)
Liked 490 Times
I've seen a few 74/130 406 wheelsets on AliExpress.
Thank you, I only need a front wheel with rim brakes.
Droid on a mission
Quoted: 320 Post(s)
Liked 286 Times
TIA
TIA
BTW @bike_forum_geek, where is the non-profit shop at?
Agreed, you can save every bike, sometime they are more work then they are worth. We rebuild about 2,000 a year in our non-profit shop and strip/recycle about another 100-150 that are either too far gone or not worth it.
Droid on a mission
Quoted: 320 Post(s)
Liked 286 Times
Hey Joe! I volunteer at BikeConcord https://www.facebook.com/bikeconcord/ , if you're in the SF Bay Area on a Thursday stop by and help us wrench I like the Bike Men Flagler website, it gave me ideas. Yea, we stripped one of the cracked frame donated fold-ables, I'm trying to save the other. If I can't find a replacement wheel I may learn to build a wheel. Checking youtube.....
BikeConcord appears to more of a bike co-op type operation, something I want to do when we get more space. We are more of a charity bike shop supporting many local groups & organizations, Haven't been to SF Bay in many years, not in the immediate plans, I really don't like plane travel anymore. PM me your telephone number and I will give you a call with the result of our wheel search.
I am potato.
Liked 1,704 Times
Base2
Car dependency is a tax.
