How much taller are 700x32 tires?
Liked 5 Times
Hi. My road bike has 700x25 tires at the moment. I'm thinking of putting something a little wider on it. It looks like I have a handful of MMs vertically for a bigger tire. So basically, how much taller would the 32mm tire be than the 25mm tire? Thanks.
Quoted: 1572 Post(s)
Liked 643 Times
What kind of brakes do you have? As a general rule road calipers max out on 28mm tires and won't open far enough to allow wider tires to squeeze between the brake pads.
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
basically the tire is (32-25) =7mm taller and wider. You'll need that 7mm clearance to the brake bridge and 3.5mm on on each side at the chain and seat stays.
Plus check your brakes.
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Quoted: 12195 Post(s)
Liked 1,497 Times
Prob not.. you could look into a Conti 28c (they run small) or if there is plenty of room the Rivendell Ruffy Tuffy 27c.
Liked 5 Times
So, when a tire is 700x??, the ?? is both sidewall height and width? Nice to know. On the other hand, Gah! I knew I should have gotten a cross bike instead. Back to the drawing broad! Thanks for the replies.
Liked 643 Times
In theory but not always in life. Rim width matters and they're not all the same. If you put a tire on a narrower rim the sectional arc distance from bead to bead hasn't changed but the beads are closer together. That means that the sectional arc is going to be tall and narrow rather than short and wide. The front of the tire will be closer to the seat tube but the sides will be farther from the chainstays.
Quoted: 2026 Post(s)
Liked 1,096 Times
Assuming a bike tire is cylindrical and the height = width is a pretty good approximation when installed on most common rims. It isn't exact, as RG pointed out, but it's close enough for government work.
For a real change take look at the 650B conversions out there! Might be cheaper than a cross-bike...
Liked 1,096 Times
There's the Tektro R556 brakes that have the reach to do it - next step up from 47-57 'long reach' (what used to be called 'standard' reach). They are 53 to 63 reach or something. Rims, spokes, brakes and tires are needed.
https://www.bikeman.com/content/view/1161/33/
Personally, I'd rather convert a 27" bike to 700C and have a better choice of tires.
If you have a roadbike, you can probably do 28c, but 32c is a bit large for some forks. Your fork, especially if is is carbon, is probably the culprit, rear clearance is probably better.
As far as shipping bike tires is concerned, UPS and FedEx charge extra for "oversize" packages, and a package with unfolded tires in it would qualify. Wouldn't weigh much, though.
I corresponded with Sheldon Brown about a month ago regarding tire sizing on the Pasela Tourguard, and he said that Panaracer sizing used to be a bit off, but is now mostly accurate.
If you want to buy a 28c tire and be sure it is actually 28c, Continental is the way to go.
I'm in Canada. It's a $$$ thing. If it goes USPS ground, then it's uninsured, untracked, and takes 3 weeks. USPS air might cost $30. UPS or FedEx will cost $25 or so, but also add a $25 to $40 'broker fee' to go through customs, and then there's the 15% tax added on to all of it. $70 tires end up at around $130. I once bought $30 in parts and had to pay $40 at the door in 'fees' to get the package. I've pretty much stopped buying anything mail order from the US (sorry). Well, except clothes from LL Bean - the products are actually shipped form Canada, so no customs 'fees' and shipping is reasonable. If Nashbar or Performance did the same, I be back on board...
I remeasured my tires. Pasela 35s on 19mm rims are 30mm high by 30mm wide - these are about 5 years old though. Continental Touring 28 are 25mm wide and 23 mm high, also about 5 years old. The Pasela have a central ridge that is finally just about worn down on mine, and this must have been an extra 0.5mm when new.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Learn how to order from PBK. If you want instant gratification, you have to pay for it.
Bikes: too many
More generally, I bought 700 x 32 (smooth center, knobby sides) against the better judgment of the LBS mechanic for a Trek 1.1 road bike. They worked fine on a recent tour. In fact, I was able to take them on and off without deflating.
It all depends on the fork clearance.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
It's not always the fork.
I run 28s on my Curtlo and it has plenty of clearance at the fork. The SRAM Force brakes, however, clear them only by 2mm...
Today, I believe my jurisdiction ends here...
Bikes: The Good Book of bicycling
Quoted: 535 Post(s)
Liked 36 Times
My touring bike came with 32's, but I changed the tires to 25's to see if there was much improvement. Hard to tell, so may slap the 32's back on again.
