Is it possible to have a 12 x 12 speed? (144 speed)
12 chain rings on the back and an identical 12 on the front. Is this somehow possible? Wonder how it would ride.
collector
I have a 30 speed now, 10 on the back, three in the front - but 144 would require two rear derailleurs to be used. sounds like an accident in the machine shop to put my feet anywhere near that much metal.
Quoted: 2026 Post(s)
Liked 1,096 Times
Well, a 14-speed Rohloff IGH used with a triple crank and a 7-speed cassette will give 294 possible combinations if you are enthralled by large numbers. But, as asked above "Why"?
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
SRAM dual drive, 10sp cassette and 3 to 5 chainrings. 90~150 gear combinations possible.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
https://www.canosoarus.com/08LSRbicycle/LSR%20Bike02.htm if ya wanna go fast!
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Think of trying to pedal a bike that has 9 more chainrings between your legs. It's easy enough to buy or build a bike that has unusable/unnecessary gears at each end of the range.
Bicycle Repair Man !!!
Quoted: 5 Post(s)
Liked 11 Times
Why? Sheldon Brown's 63 speed bike.
It's an interesting project. Impractical, but fun to think about.
Liked 5 Times
Hey, if you have to haul 1t of cargo on a bike, then 144sp could be quite desirable.
Senior member
Quoted: 943 Post(s)
Liked 659 Times
My Quetzal recumbent came with 105 combinations. Triple crank, 5 speed mid drive, 7 speed cluster on the back. I converted it to a Rohloff with a single chain ring. Still have 5 cogs on the mid drive, but no means to shift them other than by hand. All but one of the mid drive cogs put the input ratio lower than that stipulated by Rohloff, so they are just there to take up space on the freewheel.
Guess you could say it is technically a 70 speed though.
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
I'm still a believer that properly spaced 10x2 or 7x3 gives you all the gear combinations that the vast majority of riders will ever need. Heck, I remember when 12 and 15 speeds began replacing 10 speeds (5x2) and people were wondering what you needed all those gears for. There is a point where more adding gears for the sake of having more gears will produce one or more of three results: Gears so absurdly high or low as to be unusable, multiple redundant gear ratios, or gears with steps so small as to be insignificant and of no real benefit.
A friends dad same early 60's fixed up 2_3 speeds, one had 2 sprockets,
one on the hubshell . 2 chain loops..
clever machining could run 2 CV nuVinci hubs 1 driving the other, to widen the range..
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
Edit: Just remembered.. do it old school. 63 speed yo. https://sheldonbrown.com/org/otb.html
Bikes: Click on the #YOLO
Quoted: 26 Post(s)
Liked 12 Times
More ratios does not mean more range. It would be interesting to see how many of the gear combinations overlap and how many are truly unique.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Just convert to a 1/4 inch pitch chain, instead of the current 1/2 inch chain.
Then you can put 20 cogs on the back.
Sheldon Brown's Nanodrive system.
(Sheldon seems to have all the answers in this thread!)
Roadkill
Bikes: 2002 Lightspeed Classic; 2010 Pedalforce RS
Why?
The cross-chaining possibilities would be endless.
But, the trim mechanism might need some thought.
Bikes: 2010 GT Tachyon 3.0
Quoted: 45 Post(s)
You know what would be even more interesting is a bike CVT. It's doable....
Liked 2,568 Times
For what it's worth, I think Schwinn's 5-speeds gave enough range for most people (39-90 GI, roughly). But the jumps between gears would be hard to sell these days.
Liked 1,096 Times
From a historical perspective, every time an additional cog was added, there were those who loudly proclaimed it wasn't needed, the wheels would collapse, the chains would break, durability had gone out the window, etc. until they got used to N+1 only to repeat themselves the next time it happened. I've ridden 5,6,7,8,9 and 10-speed freewheels/cassettes and double and triple cranks over the past nearly 30 years and each increase brough some advantages and very few problems. There has to be a limit but I'm not ready to say where it is.
