campy shift cable too short???
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
I'm installing Campy Veloce on a CAAD8 frame. I put jagwire inline adjusters in both shift cables, the front is fine. The rear cable is at least 6" too short.
This is a set of ultra low friction cables and housing. I didn't cut much off the housing from the right ergo to the cable stop on the headtube, and I didn't cut anything off the short housing from the stop on the chainstay to the rear derailleur.
This is not a large frame (52cm) and once running along the frame, through the cable guide to the rear cable stop there aren't too many places to go wrong.
Any suggestions?
Thanks in advance.
Additional info: The rear shift cable has the factory end; it hasn't been cut.
Any suggestions?
Thanks in advance.
Dale, NL4T
Dale, NL4T
Quoted: 5793 Post(s)
Liked 2,594 Times
Two,
Find someplace to trim 6" from the housing.
Buy a longer inner wire.
Most original inner wires are 2000mm which is long enough for most situations. But those with larger frames, or long housing runs at the HB end, may find that too short.
FB
Chain-L site
FB
Chain-L site
Something is wrong, with that small a frame. Maybe they cut a cable too short. That said, there should have been a fair amount cut off the housings from the ergos to the stop on the frame. They are made long enough to use on much larger frames and you increased the length by adding adjusters. I ride a 51cm frame with a 125mm head tube and always have plenty of housing and cable length.
Liked 2,594 Times
Stupid question (maybe)
Years ago, Campagnolo supplied two inner wires of different lengths. I don't know if they still do, or if whatever kit you used did likewise. But just in case, is it possible you used the rear wire up front, leaving you the too short (front) wire for the rear?
FB
Chain-L site
FB
Chain-L site
Quoted: 2026 Post(s)
Liked 1,096 Times
I let the dogs out
Bikes: 2011 Fuji Roubaix 1.0, 2003 Ti Merlin Solis, & 1994 Raleigh MT200
Jagwire still does. I mistakenly used the rear cable from my cable kit on the front and when it came time to install the rear, I was left with a too-short cable. I had already cut the front cable (stupid mistake) and so I had to go and get a new cable for the rear
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
I'm always annoyed at how short campy makes their shifter cables.
It's even more annoying trying to get one in a tandem length.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Quoted: 294 Post(s)
Liked 137 Times
I compared the shift cables and used the shorter one on the front derailleur. I cut about an inch and a half from the housing at the chainstay to the derailleur, and cut an inch from the housing from the ergo to the frame cable stop. It is long enough now.
It just seemed odd that the cable would be too short using the delivered housing lengths on a small frame. I measured the rear cable and it was 200cm just as the directions indicated.
All OK now. I just need to get the initial tension on the cables and then do the fine tuning.
Thanks for the replies and suggestions.
Dale, NL4T
Dale, NL4T
Liked 1,096 Times
I size the shifter housing from the brifters to the frame cable stops just long enough to allow the bars to be turned fully in each direction. That gives the shortest housing you can safely use.
Quoted: 294 Post(s)
Liked 137 Times
Photos on the CAAD thread soon.
Dale, NL4T
Dale, NL4T
Super Moderator
Quoted: 1173 Post(s)
Liked 929 Times
I ride a 56, and just built up a new frame with Centaur. I had about 12" leftover on both front & rear shifters, so they seemed fine to me.
Quoted: 294 Post(s)
Liked 137 Times
Then I must still have the shift housings way too long, because on my 52cm frame I've only got an inch or so cable remaining from the clamp on the derailleur.
I obviously need to look at another road bike (that's properly set up) and compare cable routing and lengths.
Dale, NL4T
Dale, NL4T
