29'er vs 700c
29'er vs 700c
Old 06-21-12, 04:19 PM
turtle_guy
Bikes: cannondale optimo disc 2
29'er vs 700c
I was wondering if they were the same size. I ride a cross bike equipped with discs and road rims with disc hubs kinda hard to find. Other suggestions also accepted.
turtle_guy is offline
Old 06-21-12, 04:21 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Same rims, bigger tires on the "29'er" -- it's just marketing.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
Rim diameter is the same.
29'er tires are so much fatter, they get close to 29" diameter.
Rim will be WIDER for a 29'er than a road bike.
Bill Kapaun is offline
Old 06-21-12, 04:27 PM
jimc101
Quoted: 454 Post(s)
Liked 104 Times in 87 Posts
There the same size (diameter), 700c wheels will normally be much narrower than 29er wheel as 700c is used to describe wheels on road bikes, with 23-28mm tires, where as 29ers will have 2.1-2.4 tires (gota love imperial and metric measurements being mixed up for bike terminology)
The biggest difference between a 700c and 29er wheel will be a 700c has a 130mm OLD hub & rim brakes, and has a 135mm / 142.5 OLD rear hub for discs, but expect both of these to change in the next few years, with road bikes getting disc brakes, and MTB's getting wider (bolt through) rears.
Would check the spacing on your frame, as if you currently have a disc specific frame, it probably has either a 132.5 or 135mm spacing.
jimc101 is offline
Old 06-21-12, 04:28 PM
AEO
AEO's Avatar
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times in 5 Posts
29'er rims are designed to accommodate wider tires without having to worry about the tyre rolling off.
As a trade off, you might not be able to use narrower tyres.
https://www.schwalbetires.com/tech_in...dimensions#rim
note that rim width is measured from the inside.
If you measure from the outside, subtract 5.5mm, which gives an approximate result.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
AEO is offline
Old 06-21-12, 04:39 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
the hub width is likely a 135, on the frame since there are lots of disc cassette hubs .
the companies go with the best price parts pick.
so 622 rims, 135/100 hubs you're good to go..
cross /dual sport tires are about 35 wide
Road bikes are narrow tires.. 23 common.. then the rim is narrower.
fietsbob is offline
Old 06-21-12, 07:17 PM
mrrabbit
mrrabbit's Avatar
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times in 30 Posts
29'er
Just 700c with a new marketing label...that's all.
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
mrrabbit is offline
Old 06-22-12, 04:42 AM
turtle_guy
Thank you guys I was curious.
FordTrax
Bicycle Mechanics
22
09-26-18 06:15 AM
Aquakitty
Touring
41
08-08-10 01:21 PM
PCMC
Commuting
30
06-30-10 12:50 PM
hornedfrog1985
4
02-27-10 07:57 PM
