Keeping Shift Cables Off the Headtube and Fork Crown
Firm but gentle
Got any simple and elegant solutions? I'm more interested in road applications. I already know about stick-on tape, I would rather eliminate the rub altogether.
Quoted: 569 Post(s)
Liked 582 Times
These work and I have used the Jagwire protectors and they also work w/o discoloring your frame.
https://www.ebay.com/itm/114386974397?
Firm but gentle
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
What bike and which shifters? How about going around the head tube to the opposite side of the down tube if you're not already. Post a photo of your current set up.
Likes For cxwrench:
Quoted: 6193 Post(s)
Liked 4,810 Times
SRAM eTap or Shimano Di2
Liked 4,810 Times
OP mentions nothing about brake cables.
I wondered about that too, but figured it was the slap of the bare shifter cables they were more concerned with.
I suspect I'm mistaken in what the OP is asking specifically though. Maybe we'll get some more detail.
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
I’m wireless on my gravel bike, I still need tape for the rear brake hose across the head tube.
Ill probably put a little bit of a MTB frame protector sticker on it, once my new MTB arrives, if I have stickers left over.
Firm but gentle
The gray road bike has the aforementioned routing, but there is a very modest rubbing.
Likes For venturi95:
Liked 4,810 Times
Are you doing left shifter for the rear thing that confuses most of us? That does make keeping the shifter cables off the head tube difficult.
Liked 2,972 Times
thats a very up-close picture. you might be able to shorten them at the time you change there routing. i could see all that extra housing causing frame slap.
-Oh Hey!
-Oh Hey!
Bikes: lots
Liked 2,932 Times
Run them around the head tube...rear derailleur housing to the left, front to the right. They'll cross under the down tube to end up back on the correct side.
Just Pedaling
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Small zip ties kept my from being lost. One in the center worked.
Quoted: 241 Post(s)
Liked 232 Times
Putting a zip tie on the protector sort of defeats the purpose, now you have to position the zip tie so it doesn't rub the frame. I put the tube top where I want it then secure it to the housing with a drop of super glue.
Quoted: 270 Post(s)
Liked 447 Times
Super glue failed for me after a couple of months. Positioning easy to do. In my case rotating it so the end part of the zip tie was away from the frame.
Contact cement would secure them if need be.
I've never lost one but that may be a function or road bikes vs. mountain bikes.... I don't make the sharp turns or bump up and down on rough terrain like a mountain bike might do.
Bikes: N+1
Quoted: 94 Post(s)
Liked 419 Times
I run my right shifter to the left stop on the frame, and left shifter to right stop. Cross cables again under the down tube. Of course, if you have internally routed cables this probably won’t work.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Jagwire Mini Tube Tops work really well.
I got a few of them with the last Mountain PRO cable/housing kit I ordered from them.
Quoted: 1562 Post(s)
Liked 1,734 Times
You can also cross the shift cables both in front of and behind the head tube. Such that right shifter still goes to the right cable stop and left shifter left cable stop.
Another alternative is to use either Shimano or Microshift brifters with external cabling. You can set them up so that they don’t run the head tube when going straight ahead.
Quoted: 1109 Post(s)
Liked 1,200 Times
I use these things to keep the cables more or less organized and from rattling against each other. Also can result in keeping them spread out and away from rubbing the frame
20 X Rotating Bike Brake Gear Cable Protection Tidy Clip, Cross Guide S Hooks | eBay
I use these where the cables do contact the frame. They never come off
5Pcs Bike Bicycle Brake Cable Protectors Rubber Protector Spiral Hose Frame Hose | eBay
Liked 2,972 Times
-Oh Hey!
-Oh Hey!
