Check your nuts and bolts, a public service announcement. !
My wife came home the other day and handed me a 4-ish inch long bolt. "What's that?" I inquired. It was the bolt that holds on the wheel saddle. It had backed all the way out. And luck would have it she noticed it while he was loading her bike so it didn't get lost. This prompted me to go get a new tube of lock-tite, and put some on before I put it back together. Then I decided to check the rest of the nuts and bolts. While none where 'finger' loose, about half required very little effort to remove them with a wrench. Those also got a drop of lock-tite.
My advice, check yours before you lose a bike, or worse!
Likes For leob1:
Liked 2,973 Times
Good catch & luck too!
-Oh Hey!
-Oh Hey!
Likes For Troul:
Likes For trailangel:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
And Loctite should not be used everywhere, in fact very few places. Grease. Grease. Grease...and proper torque.
Likes For cxwrench:
Quoted: 2026 Post(s)
Liked 1,096 Times
Quoted: 1944 Post(s)
Liked 2,164 Times
I really haven’t had an issue with any bolts coming loose that are in one of our bikes.
I would agree with checking a bike rack. I imagine that people check their bike racks with much less frequency than their bikes; which in some cases might be a number of years.
John
John
Quoted: 569 Post(s)
Liked 582 Times
^^This is wise.^^ I have 18 bikes of my own and 6 for the kids/grandkids when they visit and just don't have a problem with grease and torquing. If you do use Locktite use the blue-242, it will come apart with common hand tools, if a very small hex head you might want to touch it with a soldering iron to heat to be sure it releases w/o stripping the hex.
We may be missing the point. There's a good chance the OP is talking about his bike carrying rig and not the bike itself. That way, "wheel saddle" makes sense
Quoted: 94 Post(s)
Liked 151 Times
Yes, anything that has fasteners on a bicycle should be checked periodically for proper torque. The torque requirements vary quite a bit, for example maybe 5 or 6nm for some handlebar clamps, to 35 or 45nm for some crank arm bolts. Torque values can be found printed on many parts that are of better quality but such parts are rarely found on lower priced bikes. Checking the torque on all critical fasteners and components of a bicycle should be performed during a routine annual tune-up. Few fasteners require Loc-tite but some do and others require lubrication. If one is unsure of proper torque or what type of lubricant to use (or how much of it) a tune-up is best left to an experienced bicycle mechanic.
Quoted: 5224 Post(s)
Liked 3,581 Times
thanks for the reminder, tho I've already been told I have a screw loose somewhere. sorry, couldn't resist
Likes For rumrunn6:
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Thule calls it a "wheel holder"... so my question... what is a "wheel saddle"
I am not a mind reader.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
Proper torque and grease or anti-seize does wonders. I don't really get a lot of loose bolts and I rarely use thread locking compounds. Not to say they don't have their usage but using instead of a place most people and companies would recommend grease or anti seize and proper torque is kind of silly.
Sorry if I wasn't clear it on the bike rack, a Kuat Sherpa.
Kuat calls it a cradle, you manufacturer name may vary.
