Max Grade: Compact vs. Double?
Bikes: Secteur, Camber, Trek 930
I was grinding away on an 8% hill yesterday and got to wondering, "Would I even be able to climb this on a standard double?" I've never ridden a standard double. What's your max grade on a standard vs. a compact?
It's easy to find out. Use a gear calculator to figure which of your gear combos with a compact would be more-or-less equivalent to your lowest gear with a standard. Then, go out and climb some hills using that gear. e.g., 34 / 21 would be just a bit higher than 39 / 25.
Philly Fanatic
Bikes: 2010 Tarmac Expert
I take my triple for longer rides where I know we will be consistently hitting grades above 13%.
on climbs with huge grades i often dont use my smaller gear, i just shoot straight up it in the big ring and a middle gear.
Quoted: 18883 Post(s)
Liked 10,646 Times
21 % (steepest road in Seattle) is a ***** in 39x25, eg on a standard double.
Quoted: 104 Post(s)
Liked 5 Times
Depends a lot on the length of the hill. I can get up short steep hills by standing on the pedals in a medium gear. For long hills, I hear that Alberto Contador used a 36x32 gear on Sunday's stage of the Giro d'Italia.
Bikes: Felt F1C
I'm on a regular double... I think most people can get up just fine until the grades start breaking 10% or as long as they pace themselves. I went on a hillside without knowing what it looked like, went max effort in the beginning thinking it would be short. Bad idea. Halfway up, I think a two year old crawling could have gone faster than me
Oh, and the max grade I've been up is 22%? Short, but hellish ride up ASU's mountain.
Dirt-riding heretic
Bikes: Lynskey R230/Red, Blue Triad SL/Red, Cannondale Scalpel 3/X9
Quoted: 5 Post(s)
Liked 8 Times
I remember being pretty happy to have a compact crankset for the last few km of Mont Ventoux.
"Unless he was racing there was no way he could match my speed."
For those that can use 39x25 on a 20% grade, are you in or out of the saddle? Above 12% on my compact 34x25 I am out of the saddle slowly grinding away.
Liked 10,646 Times
^ Out of the saddle somewhere around 15+ %, typically. It can be done seated, but it's easier and more comfortable standing.
8%, even for several miles, isn't that bad, even on a standard double. You can get stronger.
AC went with a 34X32. Higher leg speed allows for quick accelerations.
downhill quickly
Bikes: SWorks Roubaix
The gearing allows a higher cadence benefit for Conti with respect to his aerobic ability to better aid type 1 fiber to consume LA helping to fuel those steady state climbs. His standing art on pedals (the way he uniquely weights over the pedals) is more in keeping with his acceleration bursts when heis driving more anaerobic.
Beer >> Sanity
Bikes: 2014 Evo DA2, 2010 Caad9-4, 2011 Synapse-4, 2013 CaadX-disc
You'd have to be hella strong to climb a 20% with that gearing sitting or standing. No way I'll be doing that in this life (or body).
The "Mechanic"
Bikes: 2013 Tarmac SL4 Pro; 2011 Lynskey Cooper, 2015 BH Quartz Disc, 2014 Yeti SB75
My friends and I normally ride in the mountains with grades of 15%. I use a compact 12-28, my friends all ride standard 11-26 or 11-27. My friends make it up, but I always fly by them on the uphill. Hell with being macho with a standard, I prefer to enjoy my ride. Never had to walk up the mountain.
Quoted: 436 Post(s)
Liked 462 Times
I used to climb using a 39/24 and was able to power up short steep sections (< 1 mile) of 20% or more with fresh legs. I've also used triples (30/25) and compacts (34/25) and struggled up climbs of ~3-4 miles at ~10% average after my legs have already done 3000 ft. I did Palomar (I don't remember but I think it's around 13 miles at 7% average) on a 34/25 and that hurt quite a bit. Now I use 34/50 x 11/28 on the climbing bike.
Quoted: 1852 Post(s)
Liked 679 Times
I've gone up a 19 percent grade in a 39x26. I want to say it was close to a kilometer in length.
It was hard. I was swerving all over the road and actually ran off the road and had to stop. Fortunately there was a driveway just a few yards away that was fairly flat. I was able to use that to get going again and finish the climb.
Beer >> Sanity
Well, you're also probably 20 something and don't have my body either I regularly climb some 12-14% grades that are only a half mile in length (though there are several) and I'm in the 34/28 on the steepest sections just barely moving. Although, I'm getting stronger and may soon be able to not use the bailout gears.
Beer >> Sanity
