Rear Motor And Mid Motor
The main function of the motor is to generate driving torque as a power source for electrical appliances or various machinery. According to the placement of the motor, it can be divided into rear motor and middle motor.
Rear motor: compact structure, mature technology, cheap, easy to modify and repair. However, the wheel weight is relatively large, the front and rear balance is broken, and there will be inertia. Overcome reluctance while riding. Weak climbing ability.
Mid-mounted motor: The front and rear balance of the car is better. Ultra-high overall performance, reducing the leakage of wiring pipes. Excellent handling, stability and passability on bumpy roads. Higher speed due to better torque climbing capability, lower center of gravity distribution. Induction foot pedal, the controller is in the motor. Expensive. The powertrain is more prone to wear and tear, and it is troublesome to modify and repair.
Expired Member
Quoted: 3674 Post(s)
Liked 5,433 Times
Bot
Likes For shelbyfv:
Likes For Doc_Wui:
Expired Member
Liked 5,433 Times
General purpose bot, can operate anywhere.
Likes For shelbyfv:
