Why do bike tires lose air?
My tires lose 20 pounds after a simple 15-mile ride on a paved bike path. It's easy riding. But they always lose air. My girlfriend's bike tires also lose air. All bike tires constantly leak air, right?
I have Bontreger Hardcase Race Light tires. There's an inner tube, which I would think would keep air in. Unlike car tires, which don't have inner tubes, yet never lose air.
Why????
Why????
Quoted: 1074 Post(s)
Liked 295 Times
A bike tire/ tube is just a fraction of the thickness of a car tire, and it runs on a higher pressure. Air simply seeps through the rubber. The same happens to your car, but at such a slow rate that you'll be well challenged to notice it.
Quoted: 5793 Post(s)
Liked 2,590 Times
The rate of bleed depends on the wall thickness and exact material, and on the pressure which acts as a driving force. But the rate of pressure drop depends on one other factor, which is the ratio of surface to volume, As the size increases the ratio decreases so it'll take longer for a fatter tube (of the same material and thickness) to lose the same amount of pressure.
That's why narrow road tires need to be topped off every day or two, while HP mtn tires might go for a week.
FB
Chain-L site
FB
Chain-L site
Liked 7 Times
Car tires do lose air, but with a larger volume and lower pressure they lose at a much slower rate than bike tires. Insufficient air pressure is the most common cause of tread wear on cars and trucks.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,982 Times
Or it could be that you're introducing error when you measure the pressure loss.
Constant tinkerer
By the time you burp the valve (if applicable) and stick the pump head on you've lost at least 10 pounds on a narrow road tire.
If you're really losing 20 pounds every 1-2 hours (15 mile ride...) then your tires would be completely flat in a day and you have a slow leak to address,
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
It's a conspiracy -- the CO2 cartridge manufacturers are in cahoots with the tube manufacturers. Leaky tubes sell more CO2 cartridges.
It's MY mountain
Liked 2,982 Times
Liked 2,568 Times
Geck, wo ist mein Fahrrad
+1 on the leak.
Kitten Legion Master
Bikes: Fuji silhouette, Dawes SST-aL
Gah, no, you guys have it all wrong!
It's the Bicycle Tire Air Fairies, stealing your air! The more you have protecting your air the harder it is for the Bicycle Tire Air Fairies to take it. There just isn't a such evil little fairy for cars.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
Most people never deal with air pressure in their car tires as oil change shop routinely check tire pressures and top off as needed. Then most of those same people raise he!! with bike mechanics because they don't have this air pressure "problem" with their cars.
Liked 2,590 Times
There's a big difference between car and bike tires and it isn't the tires. Most car owners don't care about cars. They just want to get from place to place in comfort listening to a decent stereo. But bike owners are different, at least the ones we see on the forum. They're actually dialed into their bikes, and concerned about every creak or click, and notice things like soft tires.
Also soft tires are harder on the engine, something that's easier to notice when you're the engine.
FB
Chain-L site
FB
Chain-L site
Bikes: Specialized Sequoia Elite/Motobecane Fantom Cross Team Ti/'85 Trek 520
Why????
Why????
On my other bikes say with 700x23c sized tires, I will lose about 20 pounds within a week or so.
I used to be in rubber chemical research and did a lot of testing on componds.
Tubes are made from Butyl rubber. Its typically impervious to air and holds pressure well. Tubeless tires have a ply of butyl so they can hold air, becuse the other compounds in the "carcass" cant hold air.
I thnk the older product was made a LOT better than what we have now. Materials in todays product seem to be poor. All you can try is another set of tubes and see what leaks the least. Dont overlook the obvious like a leaky valve. That you can do something about.
-SP
-SP
They want Equality, and will always leave their high pressure job, until,
they become equal with the outside .. . levelers !
MIKE is my name!
Bikes: hans lutz, , puch mistral ultima,2x Austro Daimler Smoked chrome Ultima,Austro Daimler Mixte,Austro Daimler 531 mixte, flying arrow,F Moser,
Quoted: 7 Post(s)
Liked 20 Times
"old tubes are better"
this is interesting, I have a bike from the 50's and inside tubes are some super soft red tubes, dont know the material but they hold air just fine, 60 year tubes super soft- something has changed.
Bikes: xtracycle, electric recumbent, downtube folder and more
You just need fatter tires. I lose about 5 lbs a month in my tires on my Xtracycle, they are 1.95 running at 60 psi with extra thick inner tubes. I don't care about weight on the Xtra.
Bikes: All City Nature Boy, Salsa Ti Fargo, Kona Electric Ute
I ride my Pugsley just about every day, and checked the tires this morning after about a week and a half. I was running 11 in the front and 13 in the back. This morning, it was 7 in the front, and 17 in the back????
Quoted: 3352 Post(s)
Liked 1,056 Times
Also some tubes just hold air better than others. We are told that there are less than 5 manuf world wide of bike tires. However I have found that Bontrager tubes seem to leak down less than other brands.
Liked 2,590 Times
There are many more than 5 tire/tube makers. It doesn't matter if you count multiple factories owned by one company as one, there are still plenty more than 5 or 10. However it is true that there are more brands than actual makers. Bontrager is one example. They don't have a factory and their tires and tubes are made by one (or more) of the major producers.
FB
Chain-L site
FB
Chain-L site
Liked 2,590 Times
+1, normal bleed is 5-20#s per day or less. Significantly more than that is a leak. Most of these stable, slow leaks are at the valve.
FB
Chain-L site
FB
Chain-L site
Bikes: ‘16 Domane 4.6 Disc, ‘17 Bianchi Impulso S-Sport, ‘12 Giant Escape 0
I call shenanigans on modern cars riding around with flat tires, unless the owner is just lazy. Most all cars made in 2007+ have TPMS, and even if the tires are uniform, will warn you at 29psi or so. I typically need a cold winter to lose appreciable tire pressue, and never lose a measurable amount for months at a time in my car.
Liked 2,568 Times
