Croce D' Aune Shifters
My rear index shifter has worn out after 30 years. Can someone help with the replacement I need? I have a 6 speed regina freewheel, 13/26, Will a synchro 2 shifter work? and what color is the index part, I think its the white one? Any help would be greatly appreciated. tom
Quoted: 1648 Post(s)
Liked 843 Times
I would think a Syncro II shifter would work, especially as it was supposed to be an improvement on the first version. Just make sure you have the correct indexing insert in the lever pivot body for the number of speeds on your FW, as the indexing spacing is different for each of the inserts. There's a table floating around the forum posts that will guide you on that. Just do a search.
The Syncro I shifters can actually work very well as long as you have the correct combination of chain and FW, and adjust your cables properly to get rid of any stretch and slack in the system.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,118 Times
Syncro 2 is appropriate. Here's a link to the insert you'll need. You may not need to replace the whole shifter. Maybe just sharpen up the indentations on your current insert or a g-spring needs replacing.
https://www.cadre.org/bike_stuff/Camp...moresyncro.jpg
Quoted: 72 Post(s)
Use Syncro III shifters they have a third spring, and are better.
You find them hidden on bar ends of 9sp/10sp Time Trial shifters.
Match the 6sp index ring (color) you need based on the old chain/freewheel/shifter charts:
tears for gears: Syncro Tips and Tricks
Ignore his blog, he usually sometimes doesn't know anything of the factual history of the bicycle components he blogs about.
Veteran, Pacifist
Quoted: 3908 Post(s)
Liked 4,864 Times
Thanks guys for the references.
Learned something useful today.
Now where's the best source for adjusting Delta brakes from the CdA era???
Syncro III was also available in a downtube configuration.
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Liked 843 Times
Just installed Deltas on my Pinarello Montello a few weeks ago and they are the fussiest brakeset I ever installed on a bike (didn't help that the Pinarello routes its rear brake cable through the top tube.), and it's not just the calipers, the first gen Aero/non-aero capable levers had their own complications.
Somebody must have done a how to video on how to install these brakesets. I have not found them but you really can just figure it out yourself if you go through the install slowly and very carefully.......
Here's a few tips I can share :
Do not cut the cables till you get the calipers totally adjusted and ready to go, as you pretty much only have one shot of cutting the cables to final length as they cannot protrude more than something like a millimeter and a half or two, past the internal cable clamp.
It would also be good if you replace the brake pads with new ones, as Campy delta type brakes supposedly tend to lose quite a bit of its performance as the pads wear out. Adjust the brakes so the pads are in good, firm contact with the rim sidewalls with the cable adjuster on top of the calipers screwed out as much as possible, then you can just screw down the cable adjuster to establish final clearance between the rim and the pads once you get proper pad/rim spacing good, then, and only then you can cut the cable very close enough to the cable pinch screw so the cable end does not stick out of the caliper housing and mess with your tires below it.
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
