Rear Rack for a Book Bag?
I use a school book bag. My road bike has eyelets and braze-ons. Would bungee cords work? I never used a rack before.
May fall off if you don't know how to use your bungee cords, and bungees come off
and get stuck in the spokes.. a cause of crashes ..
I'd recommend a secure pannier on the side of the rack that can function like a backpack, off the bike..
Bikes: Raleigh Record Ace, Windsor The Hour
Get a nice and sold backpack =) I have one from outdoor products and have been using it daily for the past year and it is holding up great
Bikes: Tons
Any rack will do.
I carried my back on my rack with a basket that sat on top, threw the backpack in the basket and used a cargo bungee net thingy to keep the backpack in the basket. Worked well.
I think I'm going to buy a pannier-backpack as my current backpack has holes in it and my paper gets wet in the rain. One of zipper handles is broken but that isn't a problem. My frame is 53cm. I hope my feet/legs don't get in the way. I have a road bike not touring. I go fast and my commute is bumpy in some parts. I won't be using a heavy load.
I was thinking about this rack, Axiom Streamliner DLX. I just wonder about heel clearance.
https://www.axiomgear.com/products/ge...reamliner-dlx/
My heel goes slightly past the caliper but no more than the brake pad. Rack is 37.5cm I think. Pannier is 30cm wide. Is sizing OK?
Bikes: Workcycles FR8, 2016 Jamis Coda Comp, 2008 Surly Long Haul Trucker
Liked 6 Times
I bungee my backpack to the rack and have not had a problem. I use 2 bungee's in a crisscross pattern. The Rack I have is the Axiom Odyssee.
Looking at the axiom website I would look at the streamliner road. It says it allows for more heel clearance. On the bottom they also sell luggage straps that should work.
If you are worried about rain, I cover my backpack in plastic garbage bags. You can also purchase rain covers for backpacks as well.
Panniers carry the load lower on the bike. This helps with stability. Also Panniers can give the illusion of making you look wider than you are making cars give you a wider clearance.
Bikes: Nishiki Olympic (ret. 2010), Jamis Coda
