Sub-Compact Gearing with Wide Ratio Cassette
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times
Just wanted to share this with anyone who was interested in messing around with this:
I recently mulled around with increasing my gearing options on my gravel bike to make it more capable off-road. I have two wheelsets for my Giant toughroad: 45mm Riddlers and 50*mm Kenda Kozmik IIs (* slightly wider than 50mm). For the latter I wanted to spec that wheel out with a wider range cassette than the 11-34 that came with the bike, so I got a sunrace 10 speed 11-40 cassette and a Wolftooth Roadlink for my rear derailleur. To make it all fit I replaced the 48t big chainring with a 46t, however I left the 32t inner ring to reduce the front chainring difference. I have no idea if this is bad and even though FSA has the big ring marked as 46/30, my short test ride didn't see any issues, but we'll see what happens.
Hoping to get this onto some trails to test everything out, though that seems unlikely where I live but oh well. Overall I'm happy with how it came out.
Looks good. Can't wait to hear how it works.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Very cool.
Quoted: 1872 Post(s)
Liked 692 Times
J I have two wheelsets for my Giant toughroad: 45mm Riddlers and 50*mm Kenda Kozmik IIs (* slightly wider than 50mm). For the latter I wanted to spec that wheel out with a wider range cassette than the 11-34 that came with the bike, so I got a sunrace 10 speed 11-40 cassette and a Wolftooth Roadlink for my rear derailleur. To make it all fit I replaced the 48t big chainring with a 46t, however I left the 32t inner ring to reduce the front chainring difference. I have no idea if this is bad and even though FSA has the big ring marked as 46/30, my short test ride didn't see any issues, but we'll see what happens.
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 160 Post(s)
Liked 97 Times
In short: one wheelset is for Pavement-to-gravel and the other is for mostly off-road.
Quoted: 1104 Post(s)
Liked 1,825 Times
I'm going the other way on my Felt VR40. I'm changing the 30/46 chain rings for 32/48, but, I ride it on paved roads in foul weather, not really off road.
I'm running a 46/32, 11/42 with Roadlink on my Revolt, down from the originally equipped 48/32, 11/34. No issues with the new setup. The only time I have really needed that extra gearing is on steep, rocky gravel, and its nice to have that bailout gearing regardless.
Keith
Keith
Quoted: 160 Post(s)
Liked 97 Times
Bikes: Giant Toughroad SLR GX 1 (2018), Giant Talon 2 (2010, RIP)
Quoted: 22 Post(s)
First off nice bike, I have the TR GX1 too and it's great. I've been contemplating the other way also though, switching out the Fsa Omega crankset for a compact double, probably a 105 set due to the small difference in price between that and Tiagra but I'll wait until the overpriced BB gives up.
Looks like an interesting set up though, I very rarely touch the big sprockets on the cassette, think the only time I have was on a 50 mile trip on the South Downs Way.
Out of interest, what rims are you using for each wheelset? I was considering a second wheelset and running an aggressive tread for trails and a more slick set (Hutchinson Overide or Vittoria Zero when it's available) for smoother rides.
If you hit singletrack and steep grades, you'll probably like this. I've got 44/28 rings with an 11-36 cassette on one of my bikes. It's a dual purpose gravel/MTB/monstercross/dropbar 29er and the low end is great on MTB trails around here while the 44 keeps me from spinning out very often on dirt roads.
Bikes: K2 (Marzocchi/Fox), Trek 6000 (red) MARS Elite up front, Specialized Hardrock Sport -> eBike (R7 Elite up front), lastly TREK 820 loaner. Recently sold Peugeot du Monde Record and 1956 Schwinn (owned since new).
Quoted: 75 Post(s)
I've been thinking along these same lines A LOT ...
Want to hear more about how this works out.
I can see no downside so far ...
Bikes: 2007 Lemond Zurich, 1989 Bianchi Axis, 1983 Trek 412, 1996 Parkpre Pro 825
Quoted: 13 Post(s)
I was running a 46/34 crankset with a 11-36 cass and 10-sp Shimano SLX Shadow+ with TanPan on my Kona Jake the Snake. The local SoCal fire roads I ride have some tough 9% grade switchbacks. And the trailhead is a 7mi ride on a paved road/bike path from my house. When I replaced the Kona alloy frame with a more comfortable cromo frame, I also went to a 48/32 crankset. End result was an improved low-end for climbing and a better top-end when on pavement. I am toying with the idea of going to a 12-40 cass, but may have to go to a GoatLink to get this done.
Quoted: 431 Post(s)
Liked 460 Times
Nice, I'm also using 46/34 and debating whether it's worthwhile to go 48/32. I also had a 11-36 cassette but have since switched to a 11-40 (Rival with road link). So far I've not run out of gears on rides but the new subcompact cranks seem promising. The 48 may be better suited for the road in the 15, 17, 19 cogs.
Quoted: 13 Post(s)
Quoted: 1218 Post(s)
Liked 298 Times
I have a 11-32 to a 48/36. on my next bike, I was thinking 46/30 to a 11-34 (maybe 11-36) I think clipping along on pavement at 18-20 mph at a decent cadance is fast enough. a 46t should get me that?
Occam's Rotor
Liked 2,331 Times
The 46 X 11 gear is equivalent to the 50 X 12.
So you only lose the one highest gear. I never missed it.
I have a 46/30T on the front and either an 11-34T or 11-36T on the back, depending on the wheelset of the day. It is Di2 compatible as well.
Liked 298 Times
and the catch is in the " toying with the idea of going to a 12-40 " statement. It seems to me that the 46/30 is a better solution.
I just bought some Absolute Black 46/30 rings myself. The price is crazy for these thing but I did get lucky and find a un-used used set on ebay for a bit cheaper than new. I didn't want to have to buy a new crankset so it was either these or go the 11-40 cassette rout which I didn't want to do. This bike is my road/gravel bike and I like running an 11-32 on the road and didn't want to deal with the complications of swapping back and forth while running a bigger cassette just on my gravel wheels. I don't "need" the 46/30 on the roads around here in Wv but I've never been going up a really steep and long hill and thought "boy these gears are TOO easy". Haven't had a chance to ride in the real world yet but they work fine on the trainer, it is either raining, freezing, or both.
Assuming you're using a relatively "normal" wheel size, and you don't self-select extremely low cadences, you shouldn't need anywhere near a 46T chainring for that. If you've got a 42mm 650b tire, and you're mashing away at a measly 80rpm in a 46-11 combo, you're doing over 26mph. Heck, drop ten teeth off that chainring, down to a 36-11 combo, and you're still over 20mph.
Quoted: 167 Post(s)
Liked 11 Times
I've got Absolute Black 48/32 with 11/32 so far, it's been great.
Far better than the FSA SLK 46/30 (for sale if anyone is interested)
If I have difficulty in the lower range, I'll switch to 11/34 on back.
Quoted: 167 Post(s)
Liked 11 Times
It seemed as though the chain ring attachment would work loose and start squeaking (you need a special tool to tighten the chain rings)
I thought having a BB386 on PF30 would push the pressure points further outboard which it did but, I think it caused issues with the PF 30 because I was constantly fighting a squeak in the BB
There are those that have the SLK cranks that like them, they just didn't work for me.
