Cantilever Brakes Set Up
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 202 Post(s)
Liked 71 Times
I'm setting up new cantilever brakes for the first time. Does this look like I have it about right? I'm debating if the carrier should be a bit higher or if that is about right.
check out the Frugal Average Bicyclist
Frugal Average Bicyclist – The goal here is to help you keep cycling on a budget.
Really Old Senior Member
Adjust it to give you the pull YOU like.
Panic stops need to have an adequate leverage and you need to train yourself to use it properly.
Different hand strength/size etc.....
Quoted: 5807 Post(s)
Liked 2,628 Times
It's OK. However, I'd probably go a bit higher.
As a guide, you want the yoke to make a right angle with the arm's line of action when braking.
Note, don't be fooled by the carved arms. The issue is the straight line from pivot bolt to yoke.
FB
Chain-L site
FB
Chain-L site
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 741 Times
you're fine.. if the cable hanger gets too high, you will be pulling up on the brake arms more than inward.
I'd work on getting the straddle wire to conform more closely to the cable hanger, though.. this reduces initial sponginess when applying the brake.
get the brakes centered up well when pulled, mark the center of the straddle with a sharpie, then remove it from the hanger and bend it to follow the arch of the hanger... readjust the straddle, if needed.
Likes For maddog34:
Quoted: 516 Post(s)
Liked 452 Times
Generally, pro mechanics shoot for a 90-degree bend in the straddle cable at rest, to give the best blend of power and feel for most riders. Longer gives more power but can get mushy. Too long, and the lever bottoms out. Shorter gives quicker, more direct feel but too short can strain the hands.
If the brakes stop the bike effectively and don't scream - as cantis sometimes do - I'd call it good.
If you'd like to write a masters thesis on canti brake geometry, function, and set-up, then here is everything to know and then some!
https://sheldonbrown.com/cantilever-geometry.html
