Need help with first gravel build: LeMond Poprad Disc
Flyin' under the radar
I picked up a LeMond Poprad disc frame and I need help with my first gravel build. The previous owner "opened up the guides" to run hydraulic discs. My background is exclusively rim-brake road bikes, so I know absolutely nothing about disc brakes. I'm hoping y'all can help educate me.
End goal is Sram hydro 2x11 group, carbon fork, tubeless wheels. I'm trying to keep this budget-friendly.
Initial questions:
1. What kind of brakes does this frame take? Post mount? Flat Mount? I'm lost here.
2. What carbon fork should I get? The frame clears 700x35 tires, so I don't need anything with super wide clearance. I assume I need a 1 x 1/8 straight steerer?
3. What kind of disc wheels should I get?
4. What size rotors?
I sincerely appreciate any help you can lend.
Initial questions:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Initial questions:
Initial questions:
You don't have to get an IS mount fork, but it might be convenient. Personally, I wouldn't make that a requirement for a fork - IS mount is somewhat old, most new forks come with flat mount.
Quoted: 576 Post(s)
Liked 1,002 Times
Those older frames probably run 130mm disc hubs, which are harder to source now
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Some 1 1/8 steerer carbon fork options-
- fyxation sparta
- soma
- ritchey
- whiskey
these brands have straight steerer forks. Some are full Carbon and others have a metal steerer.
- fyxation sparta
- soma
- ritchey
- whiskey
Thank you all for your help.
What about wheels? I assume I need QR wheels, and can't use any through axle wheels (don't even really know what those are)?
Quoted: 576 Post(s)
Liked 1,002 Times
Sunshine
Liked 7,491 Times
$450 means a nice set of wheels for some and that price means entry level junk to others.
No reason to have lots of suggestions that dont apply.
Oh, and what is the rear dropout spacing?
Fair point. I'd like to be ~$300. Rear spacing is 130.
Quoted: 1872 Post(s)
Liked 692 Times
I would have ZERO reservations spreading the dropouts to 135mm so you can buy any modern QR tubeless wheelset out there.
IS mount to post or flat mount adapter for the rear brake. Whatever standard your new fork uses for the front brake.
Match the rotor size to whatever you wind up needing with the brake/adapters front/rear.
Go 1X unless you have a specific reason not to.
Use a Shimano crank instead of a SRAM crank unless you have a specific reason not to.
2019 Salsa Warbird
2019 Salsa Warbird
I have the exact frame. Used it many years with a 3x9 setup as my gravel grinder, but now it's got the original 2x10 105 that came on it.
(1) Others have already answered, IS mount.
(2) Not sure what to tell you here, I have my OEM fork - but make sure what you get has the cx-specific axle-to-crown measurement of around 400mm.
(4) 160mm. I have Avid BB7 on my setup but regardless, you want 160mm. It looks like for the rear brake housing routing, you'll need a ziptie on the left chainstay and maybe a couple elsewhere as you said they 'opened up the guides'.
It's a great riding bike. I probably have 5k miles on mine, over half off-road.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I agree with shoota - +5mm is nothing for a steel frame. I'd just get standard 135mm rear wheels.
For your front fork - you really need to know the offset and fork to crown. Any changes in this is going to change how the bike handles, as it is directly related to the bike's trail (stability). That said, a few MM (<5mm) isn't gonna be a huge change.
Quoted: 576 Post(s)
Liked 1,002 Times
That frame looks easy to spread, for sure, with no chainstay bridge. Personally I've spread a few frames with no issues, but never one with disk brakes. However, post mount adaptors do have a bit of lateral adjustment.
Thanks all for the input. Regarding cold setting the frame, is that something you'd recommend I take to a frame builder (there's one local to me), or just do it myself?
Sunshine
Liked 7,491 Times
if you do it, the spreading will most likely be even, but perhaps not exact, and the dropouts will not be aligned as exactly. That will be free.
Totally depends on what you want to do for whatever the builder charges.
Liked 692 Times
I take mine to the lbs and they do it with tools, align the dropouts (you should do this anyway before building the bike), and they only charge like $20 or something. The whole process takes less than 30 minutes.
2019 Salsa Warbird
2019 Salsa Warbird
Did you ever finish this build?
I’ve had an poprad since 2007ish and it’s been through quite a few iterations. Every once in a while I do a search on poprad builds and came across this thread.
I had similar questions/issues over the iterations so wondering what you settled with.
Current iteration is:
Just took her out for a ride yesterday. It’s been a while but when I do I realize I still love this bike!
- Ritchey carbon fork
- Campag SR11 groupset except for TRP cable disc brakes
- Campag zonda disc wheels
- Thompson cockpit and seatpost
- Self-cold-set rear stays
