Pegs on a Schwinn Cruiser?
Bikes: 1987 Schwinn Mirada, 1989 Trek 420, 1995 GT Timberline, 1979 Schwinn Super Le Tour, Co-Op DRT 1.3
Quoted: 103 Post(s)
Liked 85 Times
Yes, it's an odd question. My grade school age youngest child rides a '79 Schwinn Suburban. He wants to mount some sort of pegs on the rear wheel so when he gives the occasional lift to a friend they can stand on the pegs. Is this doable on any level? Below is the bike in question. Thanks.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Bad idea. The axles on BMX bikes are much stronger/larger than that axle not to mention it's probably not long enough to get the pegs on and then have enough threads for the nut.
Likes For cxwrench:
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times
It is a nice bike though, my wife had one just like it.
Quoted: 103 Post(s)
Liked 85 Times
I suspected as much, hence my asking before attempting. Thanks for the answers folks.
Likes For Miradaman:
Quoted: 103 Post(s)
Liked 85 Times
Looks like a pretty big bicycle for a grade schooler. I agree with the other poster that pegs on the rear axle would not be a good or safe idea for this bicycle, especially with a grade schooler trying to handle the bike with a friend perched on the rear axle.
Yeah. Why not. I'd look for a longer hardened steel solid axle. Something long enough that you've got about two inches of thread sticking out of either side. Then, install some of these things:
https://www.amazon.com/VGEBY1-Bicycl.../dp/B07QXWHQRX
It's all fun & games as long as whoever is hitching a ride doesn't weigh too much. Say like 100 pounds maximum. On flat terrain. Big downhills should be strongly discouraged. And, as long as nobodies shoelaces get tangled up in the wheel then everything should be OK.
Quoted: 103 Post(s)
Liked 85 Times
New axle must be exact same diameter as old one. So, get a measurement caliper & check. The most common rear axle diameter is 10mm. Then, figure length needed.
Likes For ramzilla:
Quoted: 643 Post(s)
Liked 1,526 Times
Back in the day, kids would stand on the axle nuts. We didn't need no fancy pegs. Did we fall off sometimes, sure. Was no big deal.
Bikes: lots
Liked 2,932 Times
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
I wouldn't do it. It is not really safe for anyone. The idea of a BMX peg is for doing tricks on a BMX bike designed for doing tricks. If you need to transport someone get a proper cargo bike with a seat on the back or at least a pad and some handlebars.
Likes For veganbikes:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Go for it. You know they’re going to try it regardless. (At least I would have at that age).
Keep in mind, “proper” freestyle bikes have 14mm axles so don’t go for ‘pro’ level parts, cause they probably won’t fit
Alternatively, you could find one of those Wald heavy duty steel racks and stick a foam pad on top of it. (I know for sure, we did that)
Likes For Ironfish653:
