Garmin cadence question
Bikes: Cannondale Synapse Tiagra, Specialized Rock Hopper
Hi everyone. I'm just getting back into riding. Been off a bike for too long. I just got a new road bike, and being the gadget junkie that I am, I couldn't help but get a Garmin 520 as well. I bought the 520 bundle. I hooked up the speed sensor and the cadence sensor. I see the speed sensor is working properly, but I can't find the cadence reading. Does this mean it's not working? The cadence sensor shows in the settings. Not sure if I did something wrong. Any help would be appreciated. Thanks in advance.
make sure firmware is most current.. make sure it connects (go to sensors screen)
Battery ? I assume you have the new one that goes on the crank arm..
Quoted: 1186 Post(s)
Liked 289 Times
It won't automatically add a new sensor. You have to go through the above steps to pair the sensor.
Ok I think that's it. I didn't know I had to pair each sensor. I thought I read that it comes with ANT in the manual and that it would pair to each other automatically. As for the speed sensor vs. Garmin's GPS recording speed, is there a difference between the 2?
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
The speed sensor is a GPS-calibrated rollout speed sensor. Using GPS, and counting wheel revs over a set distance you get a very accurate traditional rollout measurement (a normal human rollout is maybe 10 meters, the Edges do rollout calibration over 500m-1km IIRC). Then using the speed sensor you get a very consistent and accurate speed measurement no matter what braking/accelerating etc you do. GPS utilizes spherical trigonometry and Einstein relativity as applied to multiple atomic clock radio signals, and due to complexities of math and measurement-has a fair bit of lag all to do the same thing. Which is not only slower, but takes more battery. Also, bicycles don't tend to hold a consistent speed-so that lag gets exacerbated a bit; unlike a car on the interstate that tends to be one speed.
The Edge devices still uses GPS to log position to FIT riding files. The question is how it computes instantaneous speed.
Bikes: Trek 4.0 Domane
Quoted: 29 Post(s)
I'm glad someone asked this question about cadence. I still have not figured out where its located or how to view it while riding with the 520. I have a duotrap for my sensor
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Three out four Garmin sensors I've purchased have needed batteries out of the box.
Won't pair, losing connection during rides, etc.
Bikes: Trek Domane 4.3C
I have been searching threads about duotrap cadence connection problems. Did you resolve your issues? I have duotrap and just added a Garmin Edge 1000. I am unable to get a cadence connection at this time. The duotrap connected seamlessly to my Strava app on the iPhone 6.
turkey9186
4
07-03-16 09:46 PM
MikeDVB
4
05-23-14 12:47 AM
