Cruise Limit
Bikes: Trek Émonda SL 5, Trek Checkpoint SL 5, Giant Trance X 2, Trek Farley
Quoted: 74 Post(s)
Liked 94 Times
Cruise Limit
Does anyone know if there is a way to get a bike computer to remind me to ease off if I exceed a preset speed, heart rate, or other limit? I'm thinking about a bike-packing excursion, and I'm afraid I'll overdue it and be unable to ride every day. I really don't have any experience keeping a sustainable cruising pace, and when I try, I keep creeping up toward my usual pace.
I use a Garmin Edge 830 (and I also have a Garmin fenix 6), but would be willing to entertain other options.
Quoted: 821 Post(s)
Liked 1,655 Times
Edge 830 Owners Manual - Setting Range Alerts (garmin.com)
Heart rate and power alerts can be set. You can display average speed.
Quoted: 3459 Post(s)
Liked 1,466 Times
I have a basic heart rate monitor, gives me a number and nothing else. If I am climbing a steep hill, I check it often but otherwise not really needed. No alarm, just shows beats per minute on the watch screen. When it gets uncomfortably high, I stop and get off the bike.
Do you really think you need an alarm?
Quoted: 74 Post(s)
Liked 94 Times
When I try to ride at a significantly easier pace, I end up creeping back up to my usual effort. It's probably an A.D.D. thing.
Quoted: 821 Post(s)
Liked 1,655 Times
Do you have a power meter? That's what you really need. Speed can vary wildly with the same amount of effort (watts) you produce. X watts downhill will result in a much higher speed than X watts uphill. If you know what your comfortable level of watts is at your easier pace, you can set the alarm for power rather than speed.
Liked 1,466 Times
If you decide to go for a cheap non-alarm one, I got a Sigma ID.GO. I bought one from Europe and later a couple from Amazon, I install one on each bike I use so I wanted several. Now, Amazon says you need a health care license to buy one which shocks me, they did not require that when I bought in the past from them. Here is one from a European seller that I have bought from in the past. Shipping is slow from Europe.
https://www.tradeinn.com/bikeinn/en/...ch/136431995/p
This one uses an older type of chest strap, not an ANT+ type. I have some older chest straps from a company that went defunct several years ago that pre-date ANT+ that it also works with.
Good luck finding one with an alarm that meets your needs.
