Air Horns for Keeping Dogs Away?
I'm doing the TransAM trail next spring and discovering there are areas where dogs will be a real problem. Most discussion talks about using pepper spray as being a reliable solution but I thought of using an air horn. I looked them up on Amazon and see a lot of positive reviews on their effectiveness against dogs.
I should add I will be riding a recumbent with limited mobility in the seat.
Anyone use an air horn and what's your experience?
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Air horns work.
I wait till the dog gets about 3ft away then hit the horn.
Stops most of them cold.
Fred "The Real Fred"
Crankenstein
Bikes: Novara Randonee (TankerBelle)
My Delta air zound made a couple doggies do somersaults trying to get away!!! VERY effective deterrent.
Likes For bmclaughlin807:
airzounds are bad at leaking and requiring replacements every 6 months. I have one of those sports air horn type deals (actually made for boats). Unwieldy when I zip tie it to the stem, but effective and a couple times louder then the airzound.
24-Speed Machine
Bikes: 2003 Specialized Allez 24-Speed Road Bike
I have found a couple variants on the refillable air horns. The Air Zound is plastic but there is another brand made with a metal cannister. I think that is what I will get (plus two cans of high grade pepper spray). I'm not afraid of the dogs...I'm afraid of crashing and ruining my bike and the trip. Since I know I will not be able to outrun them, I will stop and walk out of their territory if the situation allows...maybe even stop and walk into their territory to nip the whole problem at the bud. But that is only if I see them first.
Bikes: Bacchetta Giro 20, Trek 7000, old Huffy MTB, and a few others
Quoted: 21 Post(s)
I've not had a problem with mine. I'm wondering if the people that have problems don't have the valve all the way open when it's being pumped up.. I keep mind wide open all the time and I haven't had a single problem. I've had it for about 6 months, so maybe I'll eat my words next summer. I'm pretty sure I would buy another one though.
Bicikli Huszár
Bikes: '95 Novara Randonee
Another recommendation for the AirZound. I've found it very effective. Stops dogs almost every time... only had to resort to pepper spray once.
FWIW, I don't fill mine very often - only at the same time I'm topping off my tires anyway. Then again, I don't honk at every little thing, only in a situation where it avoids an accident. I don't generally use it as an angry "gar, I'm mad you messed up" honk (usually. ). I've yet to have to refill before tire refill time. Never had mine leak either, but perhaps that's because I don't futz with it once I've got it mounted, aside from refills. Looks to last a second year so far...
TWilkins
Been using them against dogs for years on our tandem, but we use the cheap ones you can buy at party stores. Not refillable, so when they're done you toss them. I think we're on our second one now.
Pepper spray is a better idea from the basis that the offender will feel the effects for longer and thus have a better chance of remembering the cause-effect relationship.
Bikes: 1986 Fuji Allegro 12 Spd; 2015 Bianchi Kuma 27.2 24 Spd; 1997 Fuji MX-200 21 Spd; 2010 Vilano SS/FG 46/16
Quoted: 5 Post(s)
Will one of these work ?
https://www.autobarn.net/treldeal.html
Passive one's are cheaper but are really for cars and motorcycles and activate/operate at 35+ mph speeds.
Crankenstein
The air zound is RIGHT there, and no chance of it making you crash!
As far as leakage goes I never had an issue. I would top it off as soon as I noticed the volume start to drop off from use. Usually about once a week, unless I was REALLY mad at someone!
My biggest problem was that the mount wore out... would no longer hold the switch in place securely. Had to wrap a zip-tie around it.
feros ferio
Quoted: 1393 Post(s)
Liked 1,326 Times
Holding a water bottle as high in the air as possible and streaming its contents down and toward the pooch works every time. Someone explained that dogs interpret this as some huge animal marking its territory on them.
Bikes: Trice Q; Volae Century; TT 3.4
A quick stop combined with command voice has done the trick for me for dogs large and small both rural and urban.
aka Timi
I usually resort to doing a Lance imitation on a Tour de France spurt for a couple of hundred yards, but I get the feeling dogs are getting faster by the year
I used to have a frame pump under the TT which when raised aggressively made dogs cower, but my new one is under the DT :/
Never been sure if they really want to bite/kill/eat me when they're snapping at my furiously peddling heels... AirZound sounds interesting, especially taped to the drops (as in pic above).
"Taylor Made Products Eco Blast Rechargeable Boat Air Horn"
It's a little bigger but looks like it may be more durable. The fitting is on the bottom which is recessed.
I've also read elsewhere that a loud (120 decibel) whistle is very effective. I think it's called the Fox 40. One of the reviewers says to be careful when testing it and has never used anything else.
I've had mine for a month - haven't needed to add more air yet - last week I assumed it needed pumping, but it was still at 100psi, very near the pressure I pumped it up to a month ago.
When dealing with an attack from a wild animal the best thing to do is MAN-UP! Here is a good example:
aka Timi
Dirt Bomb
Quoted: 5471 Post(s)
Liked 288 Times
I have never tried an airhorn, but I've done the "water bottle trick" and the "stop and use a manly voice trick". Neither, to me, are reliable. Not on half-wild farm dogs anyway. Gimme my pepper spray any day. The trick is to add a clip so that the can will be held in a way that allows your finger to automatically find the trigger when you grab for it.
An Air horn sounds like a great idea. Hit the horn and it impacts EVERY dog near you. You don't need much, you don't need to paralize the dog with fear, you just need a WTF moment for the dog and you will be gone and forgotten. Someone trying pepper spray on my pair would have to be pretty good to get both and 99% would try for the wrong one first. Bad mistake as the other one is overly protective and would not take his friend being hurt well at all.
Come to think of it my biggest problem ever ws a whole feral pack. I ended up walking past them with my bike between us. If I had and tried to use pepper spray I would soon have been out and had upset dogs to deal with instead of wary dogs to avoid setting off.
