What's the best helmet mounted mirror?
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Let's not discuss whether helmet-mounted mirrors are any good, okay? I've been using them since 1979 and am a total believer.
But yesterday, when the mirror fell off the stick of my last 3rd Eye Mirror as I was crossing 5th Ave at 69th St, I decided that really was my last 3rd Eye Mirror. So... is there a good alternative?
My first helmet mirror was a single piece of wire that clamped itself to my Bell Biker helmet and had a round lucite mirror at one end. It outlasted two Bell Biker helmets and I still have it; it was indestructible! I'd still be using it, but doesn't fit modern helmets. The wire rarely got bent, but if it did, I just bent it back, and the mirror stayed in adjustment for months.
Since then I've used a variety of mirrors. Some types don't hold their adjustment at all, others hold it only for a while. And then there's the mount itself; the ones that stick to the helmet with some kind of press-on glue are the worst, the plastic shell of the helmet isn't designed to hold any glue, so the sticky stuff just fails after a while. And anyway, I use a windproof/rainproof/high-viz cover on my helmet, so I don't want anything stuck to the outside of it. So for the last ten years I've tied 3rd Eye mirrors --the glasses mounted model-- to the plastic liner of my helmet using twist ties, but I go through them too fast; they're so flimsy they rarely last more than a year before they get too floppy to hold their adjustment at all, and before long the plastic breaks anyway.
In a nutshell, every mirror I've tried in the last 20 years was junk. So... is there a good one? What do you use? What do you recommend?
Bikes: 1984 Trek 610, 1979 Raleigh Grand Prix, 2006 Kona Dew FS
I bought a "Steady Eye Mirror" through Ebay and have been happy with it--it's metal, not plastic. The only difficulty is attaching it with the clips. I've got it on the visor.
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,246 Times
He makes the best ones.
https://www.momentumplanet.ca/blog/wa...ple-nahbs-2009
Fred "The Real Fred"
multimodal commuter
Liked 574 Times
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
I personally like the Cycleaware Reflex. However, I use Gorilla Glue to attach it to my helmet, as the included "guaranteed" sticky tape doesn't work that well.
I used to use a take-a-look mirror, but having been in a pavement-kissing accident and receiving a number of facial stitches as a direct result of it having sharp edges and stiff metal pieces right next to my face, I decided the Reflex, with its bendy, rubber coated wire and round edged, plastic wrapped mirror on a breakaway ball joint was better.
I've been using the same Reflex mirror for 2 years now without any problem.
Work: the 8 hours that separates bike rides.
Infamous Member
Bikes: Surly Big Dummy, Fuji World, 80ish Bianchi
Chuck Harris
if you can't locate him or an LBS that has some of his mirrors (he doesn't get around as much as he used to) , try a Take-a-Look.
"Let us hope our weapons are never needed --but do not forget what the common people knew when they demanded the Bill of Rights: An armed citizenry is the first defense, the best defense, and the final defense against tyranny. If guns are outlawed, only the government will have guns. Only the police, the secret police, the military, the hired servants of our rulers. Only the government -- and a few outlaws. I intend to be among the outlaws" - Edward Abbey
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
My glasses at the time were very thin flexon memory frames, and the take-a-look couldn't grip it. Also, when I put a mirror on my glasses, I have to take the mirror off when I get where I'm going, then I usually forget to put it back on. When I put it on my helmet, it's always there.
I've been using take-a-look for the last few years. It's sturdy, takes abuse well, and is easy to adjust while riding.
However: I have it on my glasses, not on the helmet. The first one I bought came with a little plastic tab which was to be stuck to the helmet (but how? I can't remember), and act as an attachment point for the mirror. After I lost it (not on a bike), I bought another one and this one came without this piece of plastic. So I'm not positive it's easy to put on a helmet.
FWIW, I did use 3rd eye before, and did not like it - it felt flimsy and unsteady.
Others may know more though.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
I use the take-a-look on the visor of my helmet. Sturdy enough that when it falls off every once in a while, it doesn't self-destruct. In an accident, it would fall off before it had a chance to poke me in the eye.
747 Freight Pilot
Bikes: Rivendell, Bike-Friday Pocket-Rocket and one home made fixed gear
+1 on the Chuck Harris mirrors, unfortunately he does not get around as much as he used to. So if you get a hold of him, I'd suggest you get more than one. Below is a clip I cut-n-pasted from an article.
To purchase a mirror, contact Chuck Harris at:
Ultra-Light Bicycle Mirrors
P.O.Box 363
Gambier, Ohio 43022
or visit:
https://www.hubbub.com/store/proddetail.asp?prod=helmir
P.O.Box 363
Gambier, Ohio 43022
or visit:
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Chuck Harris was at the Hilly Hundred in Indiana in October.
+ 1 on take-a-look. As noted above, very sturdy. And yes, there is a mounting tab that can be glued to the inside of your helmet. I use Gorilla glue and a couple of clamps to ensure a strong bond and after that don't worry about it much. . .best mirror I've ever used. The metal hinges for adjustment are far better than plastic ball-and-socket connections or flex-wire on the others.
Schwinnasaur
This is what I use and found to be best after trying quite a few. But it clips to helmet visor only so you need to have a visor for your helmet. I mount mine perpendicular to the front edge of the visor. It all stainless and completely adjustable.
https://www.ecrater.com/product.php?pid=4599063
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
That's what I thought too. It didn't. It got trapped between the road and my face, and the mirror made a 6 stitch gouge alongside my nose.
cyclepath
Bikes: 2005 Trek Pilot 5.0, 2001 Specialized Sirrus Pro, Kona Lava Dome, Raleigh hardtail converted to commuter, 87 Takara steel road bike, 2008 Trek Soho
The Cycleaware Reflex for me when I wear a helmet. The Take-A-Look with clear glasses or shades when I don't. As far as risk of injury from it is concerned, I'll take the chance because it's such an effective mirror.
"Without music, life would be a mistake."
-- Friedrich Nietzsche
xtrajack
Bikes: Kona fire mountain/xtracycle,Univega landrover fs,Nishiki custom sport Ross professional super gran tour Schwinn Mesa (future Xtracycle donor bike)
My thoughts exactly. I have mine set up like this. I did not use any adhesive,just flipped the mount.
GreenwayRider
Bikes: Novara Safari, Rivendell Atlantis (on order), Schwinn Frontier, Unvigea Tandem
Liked 1,246 Times
I had them mounted on my helmet with the included piece of plastic, but I had to tape them on because that mount stinks and they were always falling off.
I know they aren't prescription compatible, but an option for others. Sorry to hear about the stitches.
https://www.amazon.com/gp/product/B00...YE0QCV0V9KKABV
Bikes: Haluzak Leprechaun, Ti-Rush, Azor Oma, Jamis Coda
I use and love EVT's (Efficient Velo Tools) Safe-Zone helmet-mounted mirror. The mirror is large (2 1/4 in. diameter) and circular, the back and edges encased in plastic, on a sturdy ball-jointed stem. It's easily adjustable and holds its position well between adjustments. I've also used the Take-a-Look and liked it okay but worried about getting cut with it if I fell; after the Safe-Zone I would have a hard time going back to the Take-a-Look.
The web address is https://www.efficientvelo.com/.
Commander, UFO Bike
I'm using the Take-a-Look, but I'm not 100% satisfied with it.
I've lost one, was riding when it was cold, and I didn't feel it when it fell off somewhere. I couldn't find it when I backtracked. I've had problems when I was involved in tackling some brush on the bike lane, and the replacement gets knocked off. The muted silver/gray/brass colors of the mirror and mounts make it hard to see on the ground (especially when fall leaves are involved).
I added a leash, and tried applying a blue retroreflective sticker to the back of the mirror to improve visiblility. However, it's peeling off the mirrored surface.
I'm thinking about a 3rd mirror, putting it on a leash, and using CA (super) glue (and insta-set) to apply a protective layer over the back of the mirror. If I do that, I'll need to make sure to keep a good flow of air over the mirror to avoid the white fogging that sometimes occurs with CA glue offgassing.
Bikes: Custom 531ST touring, Bilenky Viewpoint, Bianchi Milano, vintage Condor racer
I use the Third Eye Pro, which is a bit different from the standard Third Eye mirror.
I've been using them for years, never really had a problem with them that a dab of glue wouldn't fix -- they've recently changed the design so the socket of the ball-and-socket joint no longer cracks at the open end after prolonged use. That's what used to loosen up the ball joint so much that it wouldn't hold adjustment, and was easy to fix with a bit of glue. The Pro has a larger mirror than the standard Third Eye mirrors, too. (But nothing like that EVT, might have to try that next time....)
They can mount to the inside foam of the helmet, so they don't interfere with a helmet cover. Toss the included double-sided tape and stick them on with superglue from a hobby shop, the type that's designed for use on styrene and is toughened with some sort of rubber polymer.
On Amazon: Third Eye Pro Helmet Mirror
the best new bike helmet mirror
this may not have existed when this post was written
I tried few that fell off or didn't have a clear mirror are were not very adjustable.
This one has it all and stays on. You can move it around in many ways without it coming off and it snaps off the helmet when you want to pack it up.
https://www.amazon.com/CycleAware-Re.../dp/B01F7G5WYU
Cycle aware Relflex helmet mirror. It's awesome and it's so usable I almost look for it when I'm running!
Judy
Judy
