Where to buy pedal cages?
Hello all
I have a 2012 jamis sputnik and do not have one of the "pedal cage", which fell off. I am not sure if that is the correct name for the it but it is the black spiky ends of the track pedal on the mks sylvan stream ( i can't post links yet)
Does anyone know where to buy them? I simply cant find them. Thanks so much!!!
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Do you mean "toe clips" or "pedal cages?"
Hello All,
Thanks for ur help,
JohnDTompson, it's the 2nd picture you posted, in the plastic bag. It's not the toe clips.
The pedals that I have are the standard Jamis pedals that come with the bike, but they have a spiky "pedal cage" that prevents me from slipping when pedaling. I dont use cleats, just ride with sneakers.
If you google "mks sylvan stream", it is the first picture that comes up $74.99 on modern bike, the "pedal cage" is either silver or black.
thanks all!
Thanks for ur help,
thanks all!
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
OK, so you actually have the MKS Sylvan Stream Next pedals, which have replaceable cage plates. The regular MKS Sylvan Stream pedals have rivetted cage plates that are not replaceable. Unfortunately, I don't think MKS sells those cage plates, only the dust caps. https://www.mkspedal.com/?q=en/product/node/360
Veteran Racer
Liked 764 Times
BTW, in case you can't find your MKS Sylvan Stream Next pedal cages, you can buy a new pair of the basic model pedals from Velomine for just $28 >>> https://www.velomine.com/index.php?m...801fc8tcdbti73
Thanks so much Tejano. I actually have a pedal that looks like the MKS sylvan Stream but i have no clue what the name is.
I have a standard all city track pedal with a pedal cage that i was able to screw on to the end of my jamis sputnik pedal..... so
I was just looking for a "spiky" cage plate since my current jamis pedal has a spiky cage plate..... i may just buy the mks sylvan stream since the my jamis pedal is around 10 years old (standard jamis sputnik pedals from 2012)
thanks again!!!
thanks again!!!
