901 DA chain too soft?
I just rebuilt my drivetrain, moving up from 10s to 11s, and with Shimano R8000 components and added a DA chain in the mix.
i ended up "stepping" on the pedals a couple times, this created a clicking noise, at the same spot in the chain, which lead to the chain skipping at that same clicking noise.
so, applying too much torque to the chain can cause a fresh DA chain to stretch so much, or damage the chain.
When i got home, the chain was binding in the spot it was skipping, so i guess a DA chain down the tubes.
I am thinking of ordering an ultegra chain, hoping the extra weight will mean it is more solid to withstand use.
is this a normal thing?
Quoted: 6193 Post(s)
Liked 4,809 Times
Usually when a new chain skips on the cogs or rings, it's because the cog or ring is worn out.
Have you actually measured the new chain to see if it's worn and now out of tolerance?
What you are interpreting as binding of the link might just be the space between the teeth being too worn for a chain with the proper pitch.
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 461 Times
Is this occurring near the drive pin? Even if elsewhere, it sounds like a stiff link.
Firmly grab the chain a few inches from the kink and massage it sideways, to and fro.
FYI...chains do not stretch. Not even after hundreds of miles.
not yet. the chain has like 50 miles on it, now about 80 miles.
only the front chainring is not new. rear cassette is new,
Really Old Senior Member
Rotate the crank backwards slowly and observe the RDER.
It'll "twitch" noticeably when a stiff link goes through.
Likes For Bill Kapaun:
Quoted: 2026 Post(s)
Liked 1,096 Times
Did you join the chain with the Shimano supplied joining pin or a quick link? If it was with the pin, I expect you didn't install it correctly. They aren't that tricky but there is a technique to do it right. DA chains are very good and I expect there was an installation problem.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Are your chainrings worn. This sounds like a new chain not meshing properly with a worn ring. You said you have a new cassette and chain, but maybe your front rings are worn out - this would cause the symptoms you describe, of skipping under high power.
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
Thread derailleur
Quoted: 367 Post(s)
Liked 461 Times
Same condescending schtick you pulled on a daily basis at roadbikereview.
You should be proud that you helped contribute to that website's demise.
From what I can tell, you're continuing your best to ruin this group. Thanks.
Quoted: 2338 Post(s)
Liked 2,822 Times
I forgot you're a so-called professional mechanic that knows everything.
Likes For squirtdad:
Quoted: 1109 Post(s)
Liked 1,200 Times
Back to the issue. As others have clearly recommended or implied, the OP should first just go through the chain link by link and see if one is tight. I dont' know if they have done that yet? In the OP he said he was ready to trash an expensive chain for what's probably a minor easily corrected issue then later said he hasn't checked anything. I hope he updates.
Likes For Camilo:
Bikes: lots
Liked 2,932 Times
it is the HG 901 D/A 11s chain. current 11s chain available.
it has the quicklink, and not pin.
there is a binding on one pin, and it is not near the quicklink, and it is i think from too much force one time.
yes, the front chainring is not new. i am working on trying to decide a new front chainring, but the mileage is about 2000. the visual wear tests on the front chainring show no issues. no lifting, no spacing, no looseness. shifts clean.
I will post a video shortly. I thought this video was better, but once uploaded to YT. it loses quality. you can hear it click, and skip.
I have applied force on prior chains, the ultegra and 105 level chains with no issues in the past.
And by force, i mean going from lighter riding to a hard sitting sprint. not from a stop to a standing jump on the pedals
Thread derailleur
Quoted: 367 Post(s)
Liked 461 Times
Good thing for you there's not a thumbs-down button.
From my parts bin. Shimano sold the HG901 with pins - and no quicklink - for a good spell. And tell me if anybody ever shouted out, "Hey, get me a 901 chain." Nope. They say Dura Ace 11 speed. Gosh, I am so damaging with my poor advice.
Quoted: 581 Post(s)
Liked 921 Times
I don't doubt that a defective chain is possible, or that OP has one, but the claim that OP 'stretched' the chain by applying too much torque is nonsense. Total nonsense. Even chains that are 'stretched' after thousands of miles are not so because of excessive torque but are elongated because of wear inside the links.
Likes For ClydeClydeson:
Quoted: 837 Post(s)
Liked 1,061 Times
NO and NO. Take the advice of the previous posters and check/correct any other causes. There is a slight possibility that the chain is defective or a counterfeit and a poor one at that but I suspect something else is to blame.
Liked 1,200 Times
Likes For Camilo:
I have a video of the chain in action. not the best, but what i could grab while riding.
on you tube
YNxrVuVgF9k
or shimano dura ace chain skipping with the blue shoes.
I tried a bunch of things to try and unbind.
cleaned
re-lubed.
tried the moving, flexing, etc on the list to loosen a stuck link.
no impact.
i pulled the stuck pin, and there seems to be a slight burr that formed on it causing the stickiness.
In terms of comparing to real vs fake chains, and source, this chain should be legit. proper packaging, marks, legit bike store, hollow pins, chain markings, etc.
I am also asking, since DA are run by pros, but i presume dumped after each race/day if the lightness leads to a weaker chain, and dumping this and replacing with a lower level chain will provide more life.
or do i just stick in a couple more master links and wait for it to do it again?
on you tube
YNxrVuVgF9k
cleaned
re-lubed.
no impact.
Quoted: 837 Post(s)
Liked 1,061 Times
II am also asking, since DA are run by pros, but i presume dumped after each race/day if the lightness leads to a weaker chain, and dumping this and replacing with a lower level chain will provide more life.
Yes, just stick another quick link on there and ride it till it wears out or I'm sure there are plenty of other posters here that will take it off your hands for you so it doesn't go to waste.
Quoted: 581 Post(s)
Liked 921 Times
Defective chain? Possibly. Installation error? Also possible. Rough shifting under load causing damage to a link? That can happen too. You're so strong you damaged the chain with your massive torque? Not in a million years.
If the chains are so weak that a lay-person can damage it in 50km then a pro would absolutely tear it in half the first time they went up a hill. Even changing after every ride (which they don't generally do) wouldn't be a useful strategy if the chain failed under heavy riding forces before the end of a stage.
lets hope for installation error or rough shifting, throw a couple quicklinks in for now and go again.
Quoted: 4204 Post(s)
Liked 3,862 Times
on you tube
YNxrVuVgF9k
cleaned
re-lubed.
no impact.
on you tube
YNxrVuVgF9k
cleaned
re-lubed.
no impact.
My speculation is that the OP caused this burr with poor chain management reasons when they really went hard on the pedals. If the chain was not fully settled in the teeth valleys it would try REALLY HARD to do so when the added pedal force was applied. Andy
AndrewRStewart
AndrewRStewart
