Di2 Compatible Carbon Handlebars for fully internal wiring
Hi,
I am in the market for a fully internal Di2 compatible carbon handlebar that also fits the Shimano bar end junction box (RS910). At the moment the only ones I know about are the Pro Vibe carbon bars which have all the holes for Di2 (at the shifters and the underside of the tops). I thought the Easton (EC70 and EC90) would work but apparently you can't internally wire the bar end junction box. Looking forward to any suggestions. Aero flat tops would be a bonus (similar to the Pro Vibe Aero Carbon). Just to be clear, I am not looking for a once piece stem/handlebar combo.
Thanks!
Thanks!
Quoted: 741 Post(s)
Liked 412 Times
Hi,
Thanks!
Thanks!
Likes For colnago62:
Quoted: 20810 Post(s)
Liked 9,456 Times
I recently bought/installed (not Di2) some EC70 Aero bars and this struck me as curious - I didn't see why they wouldn't be compatible. I looked online and see a mention or two of blockage/blocking in the lever clamping area, but I distinctly remember blowing in to one bar-end (don't ask) and there didn't seem to be any obstruction at all. I wonder if they changed the lay-up process or something?
Sweet looking bars, but I don't seem to like the end of the drops where the plug is, looks a bit odd with how they taper into a point. Can this part be cut off? I am looking at the product photos and it looks like there is a circle marking, is that for cutting off a small piece from the end?
Easton needs to update the cable routing for the EC90 Aero handlebar. It is also not compatible with the new bar end junction box for Shimano Di2 due to the 3 piece construction of the EC90 Aero which makes the bar solid at the shifter clamping area. There’s not as much concern of over clamping but no way to run Di2 wires to the ends of the bar.
Aluminum bars are more shock resistant than CF. Both are built way strong enough so that the added fatigue resistance of CF doesn't matter. Today while working on my Madone, I weighed the carbon bar and stem with an equal size aluminum Cannondale stem and FSA bar and was rather surprised to find out they weighed exactly the same. Then I discovered a narrower specialized bar and it was 40 grams lighter. This makes the Aluminum bar and stem lighter than the integrated carbon bar I ordered. So you might want to think on that. Though the specialize bar has no internal runs I'm sure that they're available. And I find aluminum bars a great deal more comfortable than the oddly shaped carbon stuff on the market that is all made in China anyway.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Liked 9,456 Times
I've only read a review that mentioned that the bar end isn't connectable internally because of blockage. I don't have any retailers near me that carry them so I can see for myself. Here is the link to the article
Easton EC90 Aero Handlebar Review - The Wannabe Racer
Liked 9,456 Times
Quoted: 18883 Post(s)
Liked 10,646 Times
The SES bars are sized differently. If you buy them in 44 cm, that's measured plug to plug. The drops are flared, so the hoods are much more narrow than the sizing would have you think. All of that puts you on a more aerodynamic position.
Finally, as a general rule, wing bars are "more comfortable" because they're more flexy. These are solid. Their other road bars are actually more comfortable. But lower tech.
I am planning on doing this exact thing myself, swapping my aluminum bar and stem for the Cervelo carbon bar and stem and am a little concerned about the internal wiring routing. Makes me hesitant to tear the front end apart and then not be able to finish the job.
The bars end like any others. Instead of giving you a flat botton like thing to close the ends of the drops off, they give you a silicone penis tip. When you're wrapping the bars, that plug makes the end of the tape disappear. Supposedly they're also good for leaning your bike against the car by the bar end plug, I've never done that, there are more convenient ways. Anyway, you don't need a saw, they just pull right out.
Quoted: 741 Post(s)
Liked 412 Times
Quoted: 741 Post(s)
Liked 412 Times
A small company in Oregon called Dixie Flyer makes a track bar that will also fit brake levers. They would be great for a crit. bike. I have a those bars on my track bike with a Pro Vibe carbon stem. It is very stiff. It feels like steel stem and bars stiff.
ControlTech Cougar Aero carbon bar.
They have the same in alu.
Also found in their gravel EXL carbon bar.
Quoted: 33 Post(s)
Liked 21 Times
These bars from China are drilled for Di2 routing
I know the controversy about Chinese quality but I have a 40cm set of these bars in my possession. I have not tried to run wires through them yet but they look to be well made and purpose-built for internal routing...and they look a lot like $400 one from Enve. Mine are for sale for less than I bought them for cuz I ordered the wrong size.
https://www.ebay.com/itm/TOSEEK-Carb...72.m2749.l2649
https://www.enve.com/en/products/ses-aero-road-bar-v2/
Quoted: 416 Post(s)
Liked 699 Times
I asked this same question a few weeks ago on this forum... I ended up buying the Pro Vibe carbon bars and the Pro Vibe aluminum stem. Super clean look and they look, well, very pro! I figured you can't go wrong with Shimano's in-house brand...
Bikes: Synapse, Slate
Quoted: 56 Post(s)
Liked 12 Times
I just got an EC90 with the bar end junction installed. There may be some of the shaping bladder still in the bar, but that can be cleaned out to allow access for the wire to connect to the junction.
Looking on Amazone, this appears to be what you're looking for. https://www.amazon.com/EC90-Handleba...2C215&sr=8-103
Quoted: 3966 Post(s)
Liked 7,383 Times
Di2 fanatic
Quoted: 53 Post(s)
Liked 67 Times
I have a set of EC70 bars (bought november 2019) and they indeed to have some blockage - looks like it is still possible to run a Di2 wire through though, so I'll (try to) install the EW-RS910 sometime this month.
(if my frame arrives this month..)
