3/32" power coat white cranks/chainring
Bikes: 04 kona dawg matic, 08 kona paddy wagon
does anyone make 3/32" white cranksets? ive looked at sugino and origin8 (thyre the only ones i can think of) and from what ive seen they only have 1/8". any 3/32"?
Bikes: 1978 Motobecane Grand Touring 52/20 2008 Trek 1.2 Road Bike 1998 Canondale M800 Mountain Bike 1965 Schwinn Spitfire Cruiser 1979 Schwinn Varisty
Any reason you don't want 1/8"? It's pretty standard for singlespeed/fixed gear bikes.
well, i just got a new rear cog and its 3/32", unless someone on here wants to swap me a used 3/32" 15 tooth phil wood cog for the same thing only 1/8".
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
or you can just run a 1/8 chain on the 3/32 cog if you're that obsessed with having an all white crank with white chainring.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Brake chatter on CX forks
Bikes: '04 Kona Jake, '05 Kona Stuff, '07 Specialized Langster
The only thing that is 3/32 on either of those cranks are the chainrings. You could buy those cranks and swap out the chainring for a 3/32 one.
Bikes: Raleigh SGP soon to be fixed
just buy whatever crank arms you need (probably 165mm) and buy the chainring separately. it may cost you a few bucks more but you'll get what you want.
White 46T:
https://www.bikepartsmart.com/chainri...lver-3-32.html
White 42T:
White 46T:
White 42T:
Your cog is slipping.
I had a few white chainring back when I used to race BMX. They didn't get too dirty. Good luck finding a white 130bcd chainring, though. Your best bet is to get a silver one and spray it with two thin coats of white appliance epoxy. That paint is tough as nails.
White 46T:
White 42T:
White 46T:
White 42T:
anyone know where to find this
https://www.andel.com.tw/Archive/_eng...C1-7102_B2.jpg
Bikes: 1979 Nishiki International, 1989 Dahon folder, 1999 Nishiki Backroads, 2009 Dawes SST
