Madone owners have you gone shorter stem?
Bikes: 16 Haibike Sdruo Cross SM
Quoted: 30 Post(s)
I have had my Madone 2.1 for about 2 weeks now and think its a terrific ride. I have test ridden a bunch of bikes like CAAD 8, Synapses, Domanes, Roubaix and I think the Madone has the best front end response of them all. Yeah, biased. Ok, I test rode those and was just looking for a 2nd bike.
Now I have given up on finding that perfect mix of sport and comfort and now will try on my bike a 80mm stem soon to not stretch out just a bit.
Has any Madone owner tried 80mm? If you have what are the plus and minuses?
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
I had a "Pro" fit on Madone 4.6c and when to a 90mm stem.
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
Even though stem length isn't that critical within a fairly broad range...stem length based upon manufacture's specs tend to be frame size proportional.
For a very small frame 80-90mm will be a standard length. Most XXL frames will be the 110-120mm range for standard stem length.
But don't be overly focused on that if you need a slightly shorter horizontal reach but want the handlebar height of a larger frame. This is pretty common on non racing road bikes. Racers by contrast size their frames down to get a shorter head tube but in going to a smaller frame need to stretch out and why they need a longer stem for more horizontal reach. Recreational riders many times need exactly the opposite to get comfortable.
Beer >> Sanity
Bikes: 2014 Evo DA2, 2010 Caad9-4, 2011 Synapse-4, 2013 CaadX-disc
How long have you been riding? When I first started I ended up going from a 110 to a 100 to a 90mm stem but as I rode more I ended up going back to the 110 and eventually a 120. Doesn't mean you will eventually find the longer stem is better, but something to consider if you are still adjusting to the bike. If you do go shorter, might be worth buying a cheap stem or even borrowing one from a shop first. I now have fancy 90 and 100mm stems going unused.
Try an adjustable stem, they go for 35 bucks and they will allow you to adjust height and reach (somewhat). Once you figure the whole thing out, you can buy a nicer stem with the angle/reach that you need.
Having said this, if you end up needing an 80mm stem, there is a good chance that you may like a smaller frame size better.
If you had the bike for a couple weeks, some LBS will swap the bike with a smaller frame.
L-I-V-I-N
Not sure what this has to do with Madones? I have 90mm and 100mm stems on my two 57cm bikes (relatively short arms and the ETT is slightly different). Also have a 110 and extra 100 in the parts bin.
"The older you do get, the more rules they're gonna try to get you to follow. You just gotta keep livin', man, L-I-V-I-N." - Wooderson
'14 carbon Synapse - '12 CAAD 10 5 - '99 Gary Fisher Big Sur
Super Moderator
Quoted: 1174 Post(s)
Liked 935 Times
It is a bit like asking people what size shoe they wear. Not very relevant to oneself.
Quoted: 30 Post(s)
Still have no idea why people who don't like a thread reply.
But I don't like to argue so everyone can make fun of 2702 , that's fine with me.
So really no big deal.
Bikes: Colnago Master XL, Bianchi Via Nirone 7, Marinoni Fango
If you need a 80mm stem for a proper fit you bought the wrong size frame.
Beer >> Sanity
Judging by the saddle in that picture the frame is too big. Judging by wanting a shorter stem the frame is too big. I'm going to go out on a limb and say that maybe the frame is too big.
Quoted: 30 Post(s)
I cant stretch out as 16 years in a desk job KILLED my back.
And 48cm was too small for me. So 51cm is the one.
Not sure about bike rules about fitting from a pic since I didn't post my leg length vs torso.
If it feels good it is good, rules be dammed.
I'm 5 feet 6 so 51cm by goggling bike size charts fits.
Just a person on bike
Bikes: 2015 Trek 1.1, 2021 Specialized Roubaix, 2022 Tern HSD S+
Quoted: 132 Post(s)
Liked 86 Times
I am in a very similar situation. I also ride a 51 cm frame. I needed a shorter (80 mm) stem as I've got a pretty stiff body that won't stretch out as much as I would like. I've been doing some stretch at home lately. Hopefully this will help me get back to the stock 90 mm stem.
The value of your life doesn't change based on the way you travel. - Dawn Schellenberg (SDOT)
Quoted: 30 Post(s)
I left the 90mm on Madone but put on a 80mm stem on the CAAD and its too short and high, the steering if off, twitchy as most would call it. I am going to put on 90mm and a 7 degrees rise, same as my Madone which I think is the best handling bike I have ever tried by far.
Thread Killer
Quoted: 3214 Post(s)
Liked 1,752 Times
Quoted: 86 Post(s)
probably just to get their minds off relationships, aging , bad job, traffic, lousy weather, crime, bills...
Super Moderator
Liked 935 Times
Don't forget the all important: increase post count !
