Is there any reason to not use "wet weather" wax chain lube all the time?
Quoted: 206 Post(s)
Liked 38 Times
Wax lubes like White Lightning come in various formulations but is there a genuine reason to not use the wet weather formula all the time?
Thanks.
Thanks.
Quoted: 837 Post(s)
Liked 1,061 Times
It's an oily lube which lubricates fine in all conditions but attracts more dirt than wax types which some don't like.
Likes For Crankycrank:
Liked 2,971 Times
the point of "dry climate" lube is to not attract gunk as bad. IMO, it's pointless to use a lube that states "dry weather" & expect a cleanish drivetrain. Lawn sprinklers getcha, & if those don't a pooling puddle from them will.
-Oh Hey!
-Oh Hey!
Quoted: 2604 Post(s)
Liked 1,933 Times
For the 100 years of chained bicycles before White Lightning was invented, those chains were lubed with various oils. Only nobody called oil a wet weather lubricant, it simply worked and worked well.
Supposedly a dry lube won't attract as much dust, if you live in a desert, and won't give you an oily chain ring tattoo on your calf. Of course, if you wipe your "wet lubed" chain off with a rag every couple hundred miles, it won't have a lot of gunk on it either.
Quoted: 1944 Post(s)
Liked 2,164 Times
It really doesn’t matter. Every cyclist finds a lube, or lubes, that he or she swears by for any number of reasons.
But we should all embrace these lube threads because the day is coming when lubeless chains will be the norm. When that happens a small part of our identity in each of us will die.
John
John
Likes For 70sSanO:
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
I want belt drives for all my old bikes... between that and sealed bearings that would be maintenance heaven. And then I could tell both the waxers and anti-waxers to ALL to take a flying leap in a deep dark lake.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Liked 2,971 Times
I like it when it's wet on the chain to be able to fling off & out in to the air. The beautiful mist of spent oil+wax just seems rad.
-Oh Hey!
-Oh Hey!
