Gear inches
Bikes: 2 fixedgear, team fuji tt bike(1985) , Schwinn road bike vintage
Gear inches
I've been looking for a chart on gear inches. How to determine what's the best gear inches and how many patches do I have on my fixedgear. 🌀
Likes For sovende:
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
Sheldon or here: https://www.bikecalc.com/skid_patch_calculator
Quoted: 624 Post(s)
Liked 396 Times
I like Sheldons online gear calculator also but K Gear Software is a windows program and was written by KINETICS recumbent shop. They even have the Schlumpf gears included.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Use a 17T or a 19T cog with any chainring and you'll always have 17 or 19 skid patches!
Gear inch charts do a good enough job, but if you have 650b wheels they usually don't list many tire sizes.
If you learn the gear-inch formula and know the actual wheel + tire diameter, you don't need a chart. More accurate, too.
To get the actual diameter: Rim Diameter + (Tire Width X 2) X .03937 = Actual Diameter (in inches)
700c = 622 Rim Diameter
650b = 584 Rim Diameter
26" = 559 Rim Diameter
To get gear inches: Actual Diameter X Chainring Teeth / Sprocket Teeth = Gear Inches
Likes For Rolla:
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
Also, gear inches has nothing directly to do with how many skid patches you get. The same gear combo on any tire or wheel size will yield exactly the same skid spots locations.
Bikes: 1974 PX-10E sold, 1977 Witcomb stolen, 1980 Roberts 1 speed, 1987 Cyclops 3 x 6 friction triple crank, 2010 Masi Commuter 1 speed, 2017 Ribble 525 2 x 10 with Ergos
Quoted: 60 Post(s)
Liked 28 Times
Traditionally, racing cyclists started winter/spring riding with 70 inches (equivalent direct-drive wheel diameter) and adjusted up or down as needed. Usually, changing the rear cog by one tooth is enough to notice and matter.
That 70 inches is for racking up the winter/spring miles on the road. For stunt riding, the usual choice may be lower, perhaps 63 inches. I wouldn't actually know, but maybe somebody here does. For in-town commuting or errands, with lots of stops at lights etc and often carrying a load, I do know that 67-68 inches makes more sense than 70 inches. Pick a gear, build it up and ride it, ask yourself after a week or two if you want a higher or lower gear more often, and go up or down a cog tooth accordingly. Then it will really be your bike.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
If you have a prime number tooth count on either the chainring or the sprocket, the number of skid patches will be equal to the number of teeth on the rear sprocket.
Likes For JohnDThompson:
Quoted: 405 Post(s)
Liked 430 Times
I'm a middle-aged fat slow guy. Also, though I've ridden fixed gear and singlespeed both on and off-road, and I raced track as a junior, I actively dislike fixed and singlespeed bikes these days, and will likely never own another one.
All that said:
On my sport-touring / commuting bike, on 700cx23s, I spend most of my time, when not climbing or descending hills, in one of three gears: 42x18, 45x18, and 42x16. Or, 61.28, 65.75, and 69.17 gear inches respectively. My #1 flatland gear is the 45x18 (65.75"). A significant headwind or a long false flat will see me in the 42-or-45x20, but my 18T cog sees the most use.
All of this is on a 45/42/30x14-16-18-20-23-26 half-step triple, but I hope it might be useful to your situation.
--Shannon
--Shannon
