Road bike brake levers with V-brakes?
No, it will not work because road levers will not pull enough cable for the V-brakes to work correctly.
This is from my understanding when researching Avid BB7 brakes at least. The BB7 road version requires less cable pull for use with road levers than the MTB version that requires V-brake/linear pull levers.
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
Buy some v-brake drop bar levers, tektro and cane creek make them. I have the cane creek, very nice.
https://www.universalcycles.com/shopp...&category=2229
https://www.universalcycles.com/shopp...&category=2231
Or if you're not wedded to moustache bars, similarly shaped bars that fit mountain bike controls are available from Nitto and Velo-Orange. Trekking handlebars also provide a similar hand position.
Travel agent dual diameter pulleys sit on the brake caliper instead of the noodle.
convert cable pulled to what may work on the V brake..
I'd get cable thru the top of the lever road lever type,
that is what I use on my mustache bars, straight cable line to the brakes..
+ they pull a skosh more cable, still less than V demand, but closer..
Bikes: Trek SU100, Surly Cross Check
For the setup you describe, travel agents or v-brake road levers are your answer.
DancesWithSUVs
Quoted: 7 Post(s)
+1 Travel Agents. Converted an old cross bike from canti's to V's with them. Worked flawless.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
I like the Cane Creek Drop V levers. I converted my flat bar road bike to drop bar and used these. The hoods are nice and beefy making them comfortable to hold onto. The lever part has a nice contour and with my Tektro V brakes the bike stops on a dime. The only thing is I would add barrel adjusters to the top of the noodle on the brakes to be able to adjust tension.
https://www.canecreek.com/component-other?product=drop-v
I have those as well. The only thing I don't like about them is that the hoods aren't as comfortable to ride in as other (specifically the more pricey) options, such as the mid- to high-tier brifters.
Kid A
Liked 5 Times
With the RL520s I found that the design of the levers where the cable routes onto the handlebar is poor. The curvature of the plastic creates too harsh of a "bend" when the cable leaves the lever, creating excess friction and poor brake feel.
What I did was take a metal file and reshape the levers for a more gradual curve -- which improved braking somewhat.
Still though, traditional cantilever brakes/levers have a better feel IMO.
Daily Rider
Bikes: 89 Bridgestone MB-3, 93 Bridgestone RB-1,93 Bridgestone MB-1, 95 Klein Fervor, 02 BikeE AT, 06 Surly Cross-check, 8? Schwinn Frontier
I have both the travel agents and the Tektro levers made for v-brakes. Both work well on my Cross-check. I like the Tektros because of the simplicity of installation.
[FONT="Verdana"][SIZE="1"]
2006SurlyCrosscheck]
1995KleinFervor
1993BstoneRB1
2007IROSSBFGS
1986PanasonicDX4000
2014E-JOE
1995KleinFervor
1993BstoneRB1
2007IROSSBFGS
1986PanasonicDX4000
2014E-JOE
always rides with luggage
--Ben
2006 Trek SU100, 2009 Motobecane Fantom CX, 2011 Motobecane Fantom Cross Uno, and a Bakfiets
Previously: 2000 Trek 4500 (2000-2003), 2003 Novara Randonee (2003-2006), 2003 Giant Rainier (2003-2008), 2005 Xootr Swift (2005-2007), 2007 Nashbar 1x9 (2007-2011), 2011 Windsor Shetland (2011-2014), 2008 Citizen Folder (2015)
Non-Bike hardware: MX Linux / BunsenLabs Linux / Raspbian / Mac OS 10.6 / Android 7
--Ben
