ISO: fork for small frame
Quoted: 3810 Post(s)
Liked 6,699 Times
I'm in need of a 1" threaded fork for a small bike. Head tube measures 10.5 cm, so likely I need something with a 12-13 cm steerer. English threaded, preferably. Not fussy about eyelets or rake; as long as it's reasonably straight or easily straightened (I have tools). Plenty of bits to trade if we go that route. TIA!
Edumacator
Quoted: 2439 Post(s)
Liked 3,128 Times
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
Do you have a coop Neal? I’ll go by mine if you need and take a look. I was there not long ago and they have a bin full of threaded forks. Canti or caliper brake?
Liked 6,699 Times
Caliper brake. This is for a late model Legnano, so likely 700c wheels. I do have a couple of co-op options in case I can’t score something here.
Quoted: 964 Post(s)
Liked 1,451 Times
I have a fork threading die. So you/I could cut down something and make it work. Otherwise, also have a pretty short Vitus fork, but it has the aluminum steerer. Not sure if that is a benefit or a drawback for you, but it is what it is!! I think that's all that's available chez Carlson for now, but wanted to throw it out there!! Also I believe I owe you one.
Likes For scarlson:
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
I have a longer one from a 1970 Raleigh Record that you're welcome to have. I can send to you as-is in all its 190 mm glory, or I can cut it down (I recently got the pipe-cutter to make very neat work of it) to a shorter length so you and scarlson can tap it.
Liked 6,699 Times
Thanks for the offer, John, but I have a fork that came with this frame with a too-long steerer that Sam will work his magic on.
FalconLvr
Bikes: 62 Falcon, 58 Raleigh Lenton Gran Prix, 74 Raleigh Pro, 75 Raleigh Int, 75 Raleigh Comp, 76 Colnago Super, 75 Crescent, 80 Peugeot PX10, plus others too numerous to mention!
Quoted: 51 Post(s)
Liked 112 Times
I have a couple orphan forks that may work for you Neal, one is a Trek, Reynolds 531, campy drops, with eyelet. Steered measures 12cm, with 300mm of threads. There is some pitting on one of the tines, but still appears structurally sound and easily filled with bondo. The second one is a Tange 1L (never knew what those numbers stood for on Tange forks). It has Tange TL drops, double eyelets, and chromed crown and lower 1/3 of tines. It has 13.3cm steerer with about 400mm of threads. Of course it is somewhat heavier than the Trek. Let me know if interested! ew
