1996 Koga-Miyata SilverAce Project
#251
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
That looks fantastic! It's a shame to see the chaincase go, but the Hollowtech cranks that continue the DA 7800 styling look really good with a single ring.
Not to mention that they eliminate yet another thing for a jean cuff to get caught on; I've found that square taper cranks alone aren't a guarantee you won't somehow get snagged on the crankarm's edge around the bolt mount (then again, 517's are my go-to, so it's not as if I make the situation any easier). This crank design basically makes snags impossible.
Incidentally, I found a similar dropout configuration on an el-cheapo, wannabe-motorcycle moped recently (also found a pair of very Q-factored cranks fitted with cotters - same size as a bicycle. Mad Honk's VAR tool made removal a breeze ).
-Kurt
-Kurt
Likes For cudak888:
#252
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Hi Jaeco,
I have been inspired by your thread to renovate a well-used Gazelle tourer "Superieur Special" with a design very similar to the Silver Ace, which I took over from a senior citizen in my neighborhood. Unlike you, I decided to put minimum money into the renovation which is quite close to stock condition.“Buying price” was six bottles of red wine, and I went for the bike because it was the more rare version (for Germany) with Sachs Super7 drum brake hub and matching front drum brake. I put back the stock 32 mm tires and modified the primary gearing to 38-21 which is the lower limit of the hub (compared to stock 46-19). Because my area is quite hilly, I wanted really low gears close to 1:1 ratio. I also cleaned and re-lubricated the gear hub which was otherwise in good condition. Braking power was poor initially although the pads were OK, after putting metal instead of plastic levers and low-compression Jagwire cable housings, it improved a lot and compares to 90ies rim brakes, I would say. This bike is now my runabout-town-bike for all seasons/all weathers. I am surprised the gap between the conservative “opafiets” look and the quite sporty handling… so different from the traditional Gazelle “Speciaal” tourer that I also own.
The SilverAce is still my commuter and run-about-town bicycle here though it might need a good clean when the weather makes for some warmer evenings.
In the meantime I just added a small modification to my Carradice Bagman support. The mini rack had some issues with the small bag and the heavy Abus Granit CityChain XPlus lock, or mostly the 2+kg (4.6lbs) lock had a tendency to make the bag sag.
So I tried adding some extra supports using some spare stainless steel spokes I removed in the past from a wheel build. It didn't go exacly as planned but here's what I tried:
- Soldering them straight on.
- Nope. Turns out soldering one steel thing to another big solid steel rod is hard with a soldering iron.
- Soldering but adding some pilot holes
- Didn't work either. I just couldn't heat up the bug supports enough.
- Superglue
- Nope
- Drilling holes all the way through and just bending them around
- Yeah that worked. Not my most gracious approach but highly funtional. 2mm stainless steel drill bit and a pair of lightweight 2mm spokes worked well.
Original. Sagilicious
Supports. Drilled and bent.
Glamour shots:
#253
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
This might sound silly... but this shifter has completely changed the feel of the bike for me.
The Sturmey Archer RXL-RD5 hub came with the TSC50 twist shifter but that one felt cheap and nasty so I used the nice and sturdy SLC50 thumb shifter for the past couple of years. It has always felt a bit off though. Some of the gears felt a bit vague or would consistently overshift in certain gears which made me primarily use the second gear to start and the fifth gear when cruising.
Especially third gear was never used because the trigger part had too much play and didn't slot nicely into place all these years. And I've tried to adjust things or clean them.
But the third option in shifters is the DLC50 trigger shifter. Thumb to downshift, index finger and thumb to quickly upshift. I had read somewhere that the trigger shifter was the more exact one of the three but I did not expect such a stark difference. I probably want to try and move it up a little bit more so I get more space on the grips for my hands but other than that, let's see how these hold up.
Also, don't bother with the Ergon GP1 bioleder grips. Even when treated they soak up water and after standing and evening in the rain they will have a thin layer of mold on them in the morning. That's the bubbling you see on the grips.
EDIT: Moldy grips
EDIT: Moldy grips
#254
Quoted: 7348 Post(s)
Liked 2,474 Times
I believe it! I don't have a Sturmey Archer, but a few years ago, I upgraded our tandem from 3x7 to 3x11, and I used Deore XT rear derailleur and shifter. I've been riding bikes for a long time, but this is the best shifting I've ever had. In my case, I push with the thumb for either kind of shift, it's just a matter of which paddle to push. It's reliable and very fast.
Likes For noglider:
bigbikes
12
11-14-11 06:15 PM
