12 speed jockey wheels for Chorus 10 RD
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 231 Post(s)
Liked 377 Times
I’m running a campy 12 speed compact crank with 12 speed chain against a 10 speed chorus RD and FD.
Shifting is perfect but there is a touch of noise from the jockey wheels which probably need to be replaced anyway, are there 12 speed jockey wheels which would mount up properly to my 10 speed chorus RD?
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Quoted: 5990 Post(s)
Liked 2,923 Times
You want to stay with what you have Unless you're willing to replace both and file the screws down a bit.
FB
Chain-L site
FB
Chain-L site
Resident PIA
Quoted: 231 Post(s)
Liked 377 Times
Thanks, so RD-RE700 then?
Shad
67'er
Shad
67'er
Liked 2,923 Times
Yes, or you can price out a 12s pair along with the bolts.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 1883 Post(s)
Liked 1,755 Times
Maybe split the difference and use an 11 speed chain?
In any case, 12 speed jockey wheels are larger in diameter than 10 speed and will probably not fit the derailleur cage
