Correct psi for my tire
I just bought a new tire for my rear and only after buying it looked at what the pressure requires. It's an Ultra Cycle Flamenco, low end hybrid tire and the sidewall reads: Max. Inflate to 40 psi. No range, just that exact number. Any opinions on this? And what would you recommend I inflate it to? I'm on a loaded bike, have a thorn liner in it and I only weigh 120. I felt like I got b.s.ed with the shop's answer and KHS hasn't responded (they make them or own the company). Thanks.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
How is anyone supposed to have an opinion when you haven't bothered to say anything about the size of the tire?
Likes For cxwrench:
Dear nasty person. There it is. The bikeforums attitude I've missed. I'm sorry I'm not perfect like you - perhaps in my next life. Yes, it's a 26x1.95.
Likes For travelinhobo:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I’d start with 40 psi and see how it feels and handles. Lower it from there if you aren’t getting pinch flats and you want more comfort.
Quoted: 4806 Post(s)
Liked 3,931 Times
Fill the tires until they squish down about 1/4 -1/3 or the distance off the pavement while you sit in your usual position. Ride them. See if you'd like more or less air. (I'm guessing the first criteria will require maybe 30 psi, less in front.) Tires are not an exact science. But too much pressure can lead to the bead lifting off the rim or the sidewall blowing out or the rim sidewall breaking. Any of these events could be very hard on your eardrums.
Likes For icemilkcoffee:
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
Here, you're the one asking for free help (in terms of advice). Seems to me it shouldn't be too much trouble to provide as much info as possible up-front so that the people you're asking for help can, well, help you more easily. Doing that's also IMO likely to increase the quality of the help (advice) you get.
But that's just me. Do what you like.
Likes For Hondo6:
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
If you determine the optimal pressure for that tyre size is over its designated maximum pressure, look for a wider or higher-quality tyre (one not excluding the other).
Really Old Senior Member
Hybrids have a 622mm BSD which is about a 24.5", not 559mm which is 22".
Quoted: 4209 Post(s)
Liked 3,875 Times
This description stuff reminds me of how others who don't make their own music seem to want to apply labels to the music they don't make. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1034 Post(s)
Liked 1,290 Times
At 120 pounds, there is no way I would run 40 psi. Assuming the bike is around 30 pounds, I would go around 30-32 pounds. Probably a pound less in the front. 31F 32R is what I would do. 40 PSI will jar your teeth.
Liked 3,875 Times
So, the rider weight is not the only weight the tires are seeing. Wish we knew how much more.
No one has mentioned the tire liner. The most popular brand has a reputation of causing flats if the tires are run with too little pressures for their loads. The ends of the ribbon/liner can act as scrapers against the tube. The less the pressure the greater the squirm that results in the ribbon/liner's end chaffing the tube.
These are two reasons why the "best pressure" question is not formulaic, but experiential. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Liked 1,290 Times
"I'm on a loaded bike, have a thorn liner in it" the OP
I don't completely agree with ISO diameter dictates the bike category. The biggest example are 29ers that have "your" hybrid rim diameter but are considered the MtB way by many. In the shop I still work at (been trying to retire for a few years...) any flat bar bike with a mixed road/dirt tread is a hybrid. This still bothers me as when I see "hybrid" on the bike description I look for a 622 ISO wheeled bike too. But then it was only a decade ago when we would call a drop bar bike with 32ish wide tires that weren't CX treaded a touring bike... (Real story- On one on my first rides with the local club I rode my sew up equipped bike, double crankset, Campy short reach calipers BUT a handle bar bag over my rear wheel on my self made SPT. One guy asked about why I rode a touring bike...)
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
I like the SRAM calculator. It’s easier for me to make adjustments and recalculate. My guess is 29 psi front and 31 psi rear to start. But go try yourself. It’s fun 🤩.
https://axs.sram.com/guides/tire/pressure
