Upgrade to symmetrical dual pivot brakes
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I have a set of 105 dual pivot (asymmetrical) brakes circa 2007 which are excellent. I’m interested in the symmetrical dual pivot versions BR-5800
my questions for anyone who has experience with this:
1) is there a noticeable improvement in braking performance?
2) is there more clearance when using 28cm tires?
3) are you happy you made the change?
Quoted: 1819 Post(s)
Liked 1,693 Times
The 5800 series dual pivot brakes are designed for longer pull levers than the older pre 5700 models. They won't work very well with older levers which will be prone to bottoming out
Likes For alcjphil:
Quoted: 345 Post(s)
Liked 237 Times
if I understand correctly, it is possible I won’t get full clamp force when I engage the brakes because the levers don’t travel far enough. Correct?
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
If you want a good upgrade, get some good pads and shoes (SwissStop or KoolStop) get some good cables and housing (Jagwire Pro or Elite Link) and that will be one of the best upgrades you can do and super cheap. If you want the best brakes get the Cane Creek eeBrakes which will be a huge upgrade and something I use and love but honestly if your brakes are functional and of decent quality go with the above upgrades and save the money.
Likes For veganbikes:
Quoted: 345 Post(s)
Liked 237 Times
Likes For Symox:
Likes For Jack Tone:
Liked 1,693 Times
The brakes require levers that pull more cable than your old levers do. Even if the brake pads are almost touching the rim, your old levers may still bottom out and if your wheels go so much as 1 mm out of true the pads will rub
Quoted: 345 Post(s)
Liked 237 Times
that’s exactly the kind of information I was hoping to get. Thank you for your help. By the way I looked it up, I have ST-5600/ST-R700 series levers.
Quoted: 345 Post(s)
Liked 237 Times
Update: Thanks to all the responses I didn't change my brakes. I upgraded the pads to KoolStop salmon (they work GREAT in the rain) and cable/housings to Jagwire Pro.
Brakes work fantastic now!!!
Likes For Symox:
Clark W. Griswold
Liked 3,994 Times
To anyone out there, looking for cheap upgrades that actually do something those will work. Make sure the shoes are stiff and the pads come from a Stop (Kool or Swiss) and good compressionless housing and stainless cables without coating ideally polished will improve even a lower end brake (which 105 isn't). I will keep shouting it from the hill sides because it works.
Quoted: 1529 Post(s)
Liked 718 Times
The new generation brakes do have way more clearance. I had to upgrade my front from 7700 to 9000 to use modern aero rims {only a 23mm tubular on the front).
I do enjoy setting up this brake more, knowing that both pads are going to do the same thing as they wear; that asymmetry in the older type irked me.
Oh, and both my 7400 single-pivot rear and the 9000 seem to have a pretty suitable leverage for my Red levers, so that stuff about them being incompatible with older levers sounds a bit overblown to me.
