Squeaking
Squeaking
Hi all, I've just joined up so apologies if this is in the wrong place or I miss out a rule I didn't notice!
I've just got back into cycling after quite some time and got myself a Merida Matts 15MD. It's been a great bike for my first week or so and it's done some decent miles. It has now started making a very annoying squeaking noise that i'm hoping some of you knowledgeable people might be able to help me with. It happens without me applying the breaks - just while riding, or even just rolling the bike along the ground (so my weight on the bike doesn't seem to be a factor). I think that the sound is coming from around the area of the front disc break which sort of makes sense as if i slightly apply the break, the squeaking seems to stop, though obviously at the expense of the break then being applied which I clearly can't do for the whole ride for various reasons.
I could be wrong about where it's coming from and the sound stopping when i break might have been more of a coincidence but it does seem to point to something to do with the breaks as far as I can tell? I have heard that when you get a new bike you often need to take it back after 6 weeks or so to have cables tightened or something along those lines, but I don't know if it could be related to that because I've only had the bike a week. It's probably done about 60 miles?
Any thoughts?
Any thoughts?
Liked 2,007 Times
Guess #1, the disc BRAKE is maladjusted. (Let's hope it doesn't break!) This should be a trivial 10 minute fix if you take it back to the bike shop where you bought it, if you can avoid Friday afternoon and Saturday.
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Hold your bike off of the ground (or flip it upside down). Look at the disc brake. Look into the caliper and see if there is space between each pad and the rotor. Sometimes it helps to shine a flashlight up from the other side of the caliper. If you don't see space on one side of the rotor, your caliper is misaligned. If you do, spin the wheel. Does the rotor move back and forth at all? If yes, then your rotor is bent.
Whatever you do, if you have hydraulic brakes, don't squeeze them when the bike is upside down. It can put air into the system which can temporarily make the brakes not work well.
Probably more like a door hinge? It's not quite constant but squeaks every 5 seconds or so.. haven't had chance to get it to a shop yet..
