How to wrench like a pro - tell us what you know!
Liked 2,979 Times
some threads may have a compound in them, or the nut is "oval' to be self locking. Those instances may require extra leverage that the fingers dont directly have..
-Oh Hey!
-Oh Hey!
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
When you work on stuff like this in the rust belt
You need stuff like this. Can't be tight if it's liquid.
Likes For dedhed:
To save money for the shop (time is money), pre-stretch the brake and derailleur cables and check the tension of the spokes and adjust if necessary, then true. Fifteen minutes up front saves an hour when they bring it in for a tune-up.
Mad bike riding scientist
Quoted: 6221 Post(s)
Liked 4,221 Times
After so many years of turning nuts, I have a good success rate. How so? I remember the early days, when a rusted nut would beat me, and bring the work to a halt.
I'll start with this:
I still don't understand how this works, I just know that it does. Sometimes, a nut can be removed with fingers once the torque is released. But it's commonplace to have to use a wrench all the way if rust and gunge need to be overcome.
So ... half a turn backwards (release), a full turn forwards (tightening). Half a turn back, a full turn forwards, until the nut is off. Instead of powering on in one direction (release).
Explanation of why/how this makes it much easier to remove a stubborn nut will be most welcome. It helps to attack the visible thread with a wire brush, and to dab a spot of oil on it before starting to wrench.
Greasing bolts before installation provides a barrier against water infiltration which reduces the chance of oxidation.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,221 Times
Although derailer and brake cables are “pre-stretched”, there is still some construction stretch left in the cable. It’s around 0.5 to 1% . That may not seem like much but on a 2300mm cable, that can be 10 to 20mm of stretch. When I install derailer cables, I shift gears several times without moving the derailer then I reachor the cable and do it again as many times as necessary to get the cable so that it doesn’t stretch anymore.
Stuart Black
Stuart Black
Liked 2,979 Times
I dont 'exercise' a cable thats newly threaded thru a brifter. the act of proactively working out cable stretch expedites the infamous cable fray. Simpler to just use the barrel when lazy shifting occurs.
-Oh Hey!
-Oh Hey!
Quoted: 3514 Post(s)
Liked 2,927 Times
Never, ever use tire levers to install a tire.
Cut brake cable housing as short as possible--no loops, thank you very much.
After applying oil to a chain and pedaling/shifting it a few times--WIPE IT ALL OFF!
Never patch a tube--it's a waste of time. Just buy a new one.
Turn all cable adjusters in before installing new cables.
Tape bars from the bottom to the top.
Use a bike stand.
Use the right tool for the job.
When the bike is in the stand, turn the pedals by with your right hand and manually attempt to push the rear derailleur into the spokes with your left hand to check the limit screw adjustment.
When checking headset tightness, don't squeeze both brake levers when rocking the bike back and forth. Just squeeze the front one.
Use a bike stand.
Liked 4,221 Times
Carry both a tube and a patch kit on the road. Fix the tube when you get home.
And, as I stated in another thread, once adjusted leave the damned limit screws alone!!! Any problems with shifting has nothing…not one thing…nada…zip…zilch…to do with the limit screws after they have been adjusted.
Stuart Black
Stuart Black
Liked 4,221 Times
Patching is not only economical, it is environmentally friendly. Rubber isn’t something that can usually be recycled so just throwing it away after one use is just adding to landfills. Granted, it’s not much but it’s still wasteful. On the economical side, I have tubes with 25+ patches on them…I live in goathead country. At $3 each but usually closer to $8 each, that’s from $75 to $200 worth of single tube use. I can buy patches and fluid in bulk for about $0.25 patch job or about the same cost as a single tube.
Stuart Black
Stuart Black
Liked 2,927 Times
It won’t matter. Oil is fluid and flows under gravity. Let it stand for a little while and the oil will flow out of the chain. Turn the chain over by, for example, moving the chain 180°, and the oil will flow back down into the chain and, eventually, out again. Wiping it off constantly is simple removing the oil from the chain.
It’s only a waste of time if you are using the wrong patch kit. There are thousands of wrong patch kits and only a very few (possibly only one) that actually work. If you use a Rema TipTop kit with Rema patches and Rema vulcanizing fluid, patching isn’t a waste of time. It’s also not nearly the waste of money and rubber that constantly replacing a tube is.
Nope. Maybe for amateurs. Manually push it if you want to be sure it won't go into the spokes. It's easy. You should try it sometime at the coop.
Yeah, we get it. Good advice for noobs.
The 'bit box' ... a great friend in desperate times!
iuhefuiovnxjkmedfdfvchijndafskjfhvjnadjksfbnvcjkmx
Likes For robalong:
Liked 4,221 Times
Okay, my mistake. But I would still not cut the cable housing too short. If the cable from the shifter to the frame stops on the front is too short, the bike can’t turn properly. If the cable housing on the rear derailer is too tight, the derailer won’t work properly and/or you’ll kink the cable. And, if you have a dual suspension bike with under the bottom bracket routing, a short cable housing will cause shifting problems as the suspension moves. In other words, the housing has to be the right length.
And how often do you have to wipe your chain? Only after application or after each ride? Every oil user that I’ve run across talk ad infinitum about wiping down the chain after ever ride.
By the way, that’s not “my experience”. That’s how oil works. That’s how fluids work. They flow under gravity. It’s not something you can stop unless you cool the fluid to the point where it becomes a solid.
Throwing a tube away after a single puncture is a waste of money and resources.
Um…yes. Having a little bit of adjustment in both directions comes in handy down the road. It may not be needed all the time but it’s nice to have.
How about a bit of respect. I didn’t call you an amateur. On the stand, you can easily shift an untuned derailer so that the derailer doesn’t go into the spokes. Once into the low gear, stop pedaling! Then move the shift lever (again without pedaling) and see if the rear derailer moves. No risk of sending the chain into the spokes because the chain isn’t moving. The small amount of movement using the cable is also easier to see how much the derailer is off than moving it by hand. You are going to have to test the limits during a shift anyway, so why not begin there?
And, yet, I see so many people who start with limit screws to try to “fix” shifting.
I guess in your experience. My chain is perfectly clean AND oiled. And there is no oil on the outside.
Nope. Waste of time.
Um...no. With new cables, all the way in. YMMV.
Stuart Black
Stuart Black
Liked 2,927 Times
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
The comments about stuck hex nuts got me thinking...I can't remember the last time I turned a hex nut on one of my bikes. On my 3 most current bikes, I don't think there is a single fastener that is a hex nut. Everything is Allen or Torx.
Likes For Eric F:
