Looking for clamp-on brake levers
A guy who rides bikes
I don't know if anyone makes these, but I can't find a source if they do exist. Basically, I'm looking for normal road brake levers that clamp on like CX levers do, with a hinged clamp.
Right now, I have a set of Tektro CX levers on my bar, which I can easily take off for the times I go to the track (on the road I ride SS): PIC
I'd rather have normal drop bar levers, since they're easier to get to when riding in the drops, where I spend most of my time. But, I'd like something that quickly clamps on/comes off, instead of having to remove bar tape and slide them into place.
Grumpy Old Bugga
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Quoted: 370 Post(s)
Liked 8 Times
I don't have an answer mate, but do wonder of your solution might lie in having two sets of bars, one set up for the track, the other for the road. The open faced neck would make the change over very simple.
Your cog is slipping.
If such a thing did exist (which I'm pretty sure it does not), would your bar tape just have a huge gap in it while the levers aren't present?
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
Two bars, one bike.
Goes to 11.
Bikes: 2015 Soma Double Cross
Bars++. You need to undo 5 bolts (at most) to swap a set of bars, and if you draw a chalk line or something on the stem/bars to maintain orientation, you can probably do the swap in less than 5 minutes.
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
Use a non-aero lever & cloth bar tape. The lever needs to be the type with an separate nut and band like the older GB's. The lever goes over the bar tape. To remove the lever, slack the cable, run the bolt out and pop the clapband off the bar. Re-insatllation; open the band a bit & position on the bar& squeeze it back around the bar, gently place the lever over and tighten the screw.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
What are your plans for going up to the track? Are you going to be joining us for some Thursday night races? Or will you just be up there riding for fun?
Yeah, after weighing all my options, this is what I've decided to do. I can remove the one bar with levers and brakes all in one piece, then just bolt the other bar on.
So far, I've just ridden it for fun while I'm in StL at my in-laws from time to time. If I ever happen to be there on a Thursday night, I'll definitely come join in. I wouldn't mind having others to draft off of, since the wind inside that bowl is ridiculous.
It can get pretty gnarly down there, but summer is usually less windy. Next time you are going to be in town send me a message. I am always down to ride the track with people. And hopefully we see you out for some racing. The vibe up there is really cool. Very much a DIY family situation.
Cool, I'll try to remember to.
Question: what tire sizes do most people run there? I've tried 23c, and that was horrific. So, I went to 25c, which are sized almost as large as a 28c (Conti 4000S), and run tire pressure around 85psi, down from 100psi on the road. It seemed to make quite a difference over all of those cracks.
Most people are on 23s with around 90-100 psi. It takes some getting used to, but thats what balances things out well.
